tweaked hood... aftermarket support?
Discussion in 'The Garage' started by jekbrown, Nov 10, 2005.
  1. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    My new tow rig has the classic 70s Chevy tweaked hood (trying to 'fold' in the middle). The sheetmetal actually isn't screwed up to bad yet (i've seen worse)... would a set of those JC Whitney support/repair brackets fix the problem? If I can just get everything straight and looking decent, I'll prolly just pull the springs and use pins in front. Anyone tried these or does everyone just head to the scrap yard to find one that isn't tweaked yet? lol!
    j
  2. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    I've got a set of the hood reinforcers that I've never used because the hood on my blazer already has some flat stock welded in for support. If the metal isn't fatigued, and looks straight, you could get the reinforcements for less than a new hood and be OK.
  3. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    never used them eh? wanna sell 'em? You'll get an honorable mention in my upcoming tow-rig buildup thread... :grin:
    j
  4. guido666
    guido666 1/2 ton status
    Feb 16, 2005
    788
    Longmont, CO
    If you don't want to waste all that money and shipping, just go get some flat stock from Tractor Supply Co. or whatever local hardware type store you have there. $5 and a handful of rivets or screws and you'll be golden. :D
  5. ZooMad75
    ZooMad75 1/2 ton status Premium Member GMOTM Winner
    Apr 5, 2003
    1,008
    609
    Pueblo, CO
    You don't need to take the springs out and use pins. Put the reinforcement on and then lube the snot out of the hinges. I used a spray white grease that stay put quite well. My 30 year old hood has no kinks and shuts like it should.
    One key tip is to always push back on the hood before pulling it down.
  6. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    ok cool... I'll give it a shot. :) I kind of like hoods that are simply held up with the steel rod thingy... no springs or whatever at all. Simpler system, lighter and tends to not damage hoods in any way. lol! I'd like to go pins because my 75 has no hood release inside the cab... its just a lever at the grille. Not the best with respect to a security standpoint... locking hood pins would be better. I don't need clowns prowling around under the hood of my tow rig! :thumb:
    j
  7. guido666
    Feb 16, 2005
    788
    Longmont, CO
    That works well on a Civic, but when your hood weighs 80lb. it's a little different. Your hood is also quite a bit off the ground I assume. My K5 with 4" lift, 3" body lift, and 40" Boggers has the hood at about chin level shut (I'm 6'2"!). So open it's about 9' in the air!
  8. 78Suburban
    78Suburban 1/2 ton status
    Jul 4, 2005
    2,609
    Georgia
    Where can you find locking hood pins, and how hard are they to install? I would like any hood pins for that matter.... I want to put them at all 4 conrners, for ease of removal (so I can climb over in there to work on stuff)... How hard are they to install?
    PS: my hood has that kink in the middle also.... :doah:
  9. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    Lifting my K5s hood isn't really that hard... sure, its heavy, but its not THAT heavy. My ranger/explorer use this system and it works great.
    Not really, this is for my tow rig... its pretty much a low rider. My K5s hood is way off the ground, but it isn't tweaked. ;)
    Summit has them.
    Actually, removing a steel hood that is fully pinned on it not that easy at all... gotta lift it off and there are no factory "handles" to really do so. I think hinges in the rear and pins in the front is the best alternative. As far as getting room to work, if I was you I'd just figure out a way to use jeep hinges... then you could open the hood all the way up, letting it rest on the windshield. Ought to give you plenty of room to work...
    Never installed pins... but they aren't that hard from what I can tell. Once you have a mounting system fabbed up for the pin itself, its just a matter of drilling a hole in the hood.
    annoying isn't it! ;)
    j
  10. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    a quote from: http://coloradok5.com/forums/showthread.php?t=147834&highlight=head
    if it bothers you that bad, replace the hood, and perform regular maintnance on the hinges. its not worth your head in a front impact crash to save the money.
  11. hawkeye649
    hawkeye649 1/2 ton status
    Mar 26, 2004
    848
    New Hamp-shi-ah
    AutoZone sells locking pins for $20 bucks for 2. Put them on my s10 after I hit a shopping cart.... pussy truck.
    I'd just like to know.... who starts haulin down so hard on their hood that they bend it?? "It wasn't working right, so I just sat my fat girlfriend on it, hit it with the 10lb persuader. I can't understand why I don't have the fit on the hood I used to... strange"
    GMC Graemlin
  12. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Jason, I made my own out of 1/8" c 2" flat stock and about 2 feet or so long. I'll try and get some pics of them for ya tomorrow.
  13. tomseviltwin
    tomseviltwin 1/2 ton status
    Dec 23, 2001
    2,065
    Utah
    I've got a straight hood you can have for free. Trouble is it's in Utah.
  14. outlawtorn
    outlawtorn 1/2 ton status
    Jul 21, 2004
    365
    Box Elder, SD
    :rolleyes: I just welded some flat stock there like everyone else... i dont run fenderwells so its a huge PITA to keep the hinges clean and working..
  15. trailblazr81
    trailblazr81 1/2 ton status
    May 27, 2005
    931
    Hollister, CA
    I had that problem, even ripped the metal. I banged it back flat, welded it up and lubed the hinges/springs. Works fine now. I had the locking hood pins on a 69 Malibu back in the day. Tho I wonder how well they work after all the dirt, trail dust, and mud thrown at 'em?? :confused:
  16. dyeager535
    26,980
    It's a flawed design to start with, I'm sure as mentioned coupled with hard to close hood hinges, failure is guaranteed. It's not like it takes much force to start it bending, over time it's just going to bend more.
    Those are crumple points for the hood put there by GM. The later hoods changed the spring setup and obviously the hood itself, thus this problem was (mostly) eliminated. I'm sure there is someone out there with an '81 up that has a problem like this, but it's not because of the overall design.
  17. 78Suburban
    Jul 4, 2005
    2,609
    Georgia
    Has anyone done this? Seems like a brilliant idea... I would love to see some pics if anyone has..... I just may try to find some hood pins and jeep hinges.. Wonder where I can order some jeep hinges new, because I don't think many are parted out around here very much......
  18. Brocky
    Brocky 1/2 ton status
    May 22, 2005
    1,170
    St.John's Newfoundland, Canada
    I got a strip welded on aswell. I know how hard they can be to close. I just sprayed mine to death with rust check and now it glides up and down. After all the years tho my hood pops up on the windshield side. I can push it down but it pops back up fiirst bump I hit. Anyone else have this problem and know for a solution?
  19. mouse
    Nov 10, 2003
    1,448
    Great Falls Mt
    I would sell these cheap, but even though you are relatively close, it would probably be $10 to ship. I bought them from LMC and they are complete with all hardware. All of it is still sealed in the original plastic. They don't look hard to make, but this stuff is ready to go...
  20. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    I'll prolly go built-not-bought on this one I guess. I have some flat stock laying around already. Add screws and/or tack welds and I'm set.
    AFA the jeep hood hinges, I'm going to do that on my K5 as part of the narrowing project. Pics of the whole process will be posted, of course.
    j
