twin stick 205
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by jasonkh2tg, Apr 6, 2003.
  1. jasonkh2tg
    jasonkh2tg 1/2 ton status
    Mar 27, 2003
    139
    MPLS MN
    Im going to be doing a complete rebuild on my NP 205 new seals and bearings and gaskets...Ive been thinking about going to a twin stick..If I do that would I have to remove the detent pins to get complete control of each shift rail.??? just wondering if any one has done this before and any insight would be great..pro's con's anything...thanks..
  2. 1Blazin71
    1Blazin71 1/2 ton status
    Aug 23, 2000
    112
    Los Angeles
    Search. There's been several posts that include an article from 4WDOR on how to grind the shift rails to allow front and rear to enagage separately, without the possibility of having one in hi and one in low.
  3. Mudstud
    Mudstud 1/2 ton status
    May 29, 2001
    1,472
    Memphis, TN
    Yes, do a search. I have some pics of mine in the link below. To answer your question- no you don't remove it. You do take it out to remove the rail but you DO put it back in.
  4. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    mudstud
    i was gonna tell him to talk to you.
    no5 clicky
    clicky 205 #2
    hope these links help. that is if they work.
    also mj has some good stuff.
    nathan
    69K5
  5. jasonkh2tg
    Mar 27, 2003
    139
    MPLS MN
    Finally... twin stick 205 I got mine today just keep in mind that there is no bushing where the shifter bolts to the adapter..I think the original one will work...I'll have to find out...
  6. mosesburb
    mosesburb For Rent Premium Member GMOTM Winner
    Apr 20, 2003
    2,172
    128
    Phoenix AZ
    In the Garage forum, there is a post called "updates on Truggy" by BadDog. In there you will find a link to his site, and in his site there is a section about this with the Petersens Off Road article and some detailed instructions following the article. Hope this helps /forums/images/graemlins/cool.gif.
