Twin turbos on a 6.2?
Discussion in '1982-Present GM Diesel' started by jarheadk5, Jul 23, 2004.
  1. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    Since my upcoming 6.2 swap is a long-term project, and I DO want to force-feed it eventually, I keep thinking that I should start gathering the stuff to install a turbo while everything's apart. You know, that whole trying-to-think-ahead thing, and not repeating tasks like front clip removal... But I digress.
    Anyhoo, my cousin and I were kickin' some ideas around last night waiting for his cousin to show so I could check out the donor truck. One of the ideas was a twin-turbo setup, which of course got the ol' mental hamster wheel to spinnin'. /forums/images/graemlins/thinking.gif /forums/images/graemlins/thinking.gif Now I'm no turbo wizard, but I have read just enough to make me dangerous... /forums/images/graemlins/whistling.gif
    Sooo, knowing that two smaller turbos can make as much (or more) power as a single big turbo, but without the turbo lag issues... would 2 small turbos (obviously, 2 of the same type), sourced from some import app, work on a 6.2?
    Now before anyone says it, I know that this would require some fab work; exhaust manifolds/headers and the intake plumbing probably being the biggest headaches. And I have no idea what apps would have turbos of the appropriate size/flowrate/??. I imagine if I lurked around on some of the import racing sites (racers, not ricers... /forums/images/graemlins/wink.gif) I could probably find some flow info on various import-car turbos.
    /forums/images/graemlins/thinking.gif /forums/images/graemlins/thinking.gif /forums/images/graemlins/thinking.gif /forums/images/graemlins/thinking.gif /forums/images/graemlins/thinking.gif
    So, is this:
    A: just a pipe dream that I should walk away from /forums/images/graemlins/screwy.gif
    B: possible, but not worth the hassle/expense on an off-road truck /forums/images/graemlins/dunno.gif
    C: an interesting concept that just might turn my humble 6.2L diesel into a tire-shredding, axle-snapping terror /forums/images/graemlins/histerical.gif
    I anxiously await opinions/firebombs...
  2. BlueBlazer
    BlueBlazer 1/2 ton status
    Feb 15, 2001
    1,940
    Unless you are racing it or doing sled pulls, dont waste your time. If you do go through with it, head studs and some sort of aftermarket head gaskets as well as low compression pistons are a must.
  3. tRustyK5
    Jul 23, 2000
    36,188
    1,396
    E-town baby!
    I like it.
    The good thing with turbo-ing a diesel is you don't have to worry about fuel mixture issues, just EGT's which you'd have a guage for anyways.
    I have a set of H1 headers that would probably be easy enough to modify, and the intake issue would'nt be to hard to do. I think the tough part might be plumbing two downpipes.
    As for sizes, beats the hell out of me. Maybe the turbo's they used on the typhoon or GN would work. Run a pair of them...
    Biggest issue is not to overboost the engine and cause a catastrphic failure. Stock they have cast pistons and stuff. The later 6.5 TD's ran (marginally) better pistons with oil spray un the underside to help keep them cool. I think the weak point would be in the bottom end on a used motor.
    I can see 220 and 500 at the wheels with a twin turbo though...which would shred tires nicely i'd think.
    Rene
  4. arveetek
    arveetek 1/2 ton status
    Mar 1, 2002
    722
    Granby, MIssouri, USA
    Peter Bierman from the Netherlands, a www.thedieselpage.com member, installed twin turbos on his 6.2L Blazer. It was quite a chore. He fabricated his own exhaust manifolds from scratch, and mounted one turbo on each side. He also lowered the compression ratio by milling off the tops of the pistons a bit. Performed really well, although he just recently blew his head gaskets. I don't know if he's finished yet, but he was also installing a 300hp Peninsular fuel injection system.
    You can read the article if you order this book. My advice: become a member and you can read all these articles when they get posted online! That's one of the greatest benefits of being a DP member.
    Anyway, a twin-turbo project is not for the faint-hearted. It would be cool, though!
    Casey
  5. AgDieseler
    AgDieseler Certified Scrap Producer Premium Member GMOTM Winner
    Jan 25, 2001
    1,045
    1,126
    Dallas
  6. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    So, is this:
    I say if you have the time, go for it.
    I have a couple of engines that are rebuildable and I want to rebuild one to have 2 turbos on, and it will be a while before I get it finished but I just want to do it.
    I also have the perfect truck to recieve it too, I am building it this winter.
  7. jarheadk5
    Mar 6, 2000
    4,389
    PA
    Just a bit of clarification...
    I'm not looking to "bomb" this motor, or make super-high boost pressure. I'm just thinking, based on stuff I've read before, that a twin-turbo setup with small turbos will have better throttle response and less turbo lag at low RPM's. Is my thought process on this correct?
    For me, the point of the exercise would be better throttle response and power at low RPM's for offroading, with the fuel economy inherent in a diesel. If I tow anything with the truck, it won't be real heavy; 3-4K lbs. max.
  8. BlueBlazer
    Feb 15, 2001
    1,940
    Go with a correctly sized wastegated turbo instead of twins, you will be much happier and a lot less work.
  9. tRustyK5
    Jul 23, 2000
    36,188
    1,396
    E-town baby!
    Even a NA 6.2 has exceptional throttle response and off idle torque. IMO a turbo on a 6.2 is not needed for wheeling, especially if you're crawling.
    Even a quick spooling turbo wouldn't be making much boost at 1000-1500 rpm anyways.
    Rene
  10. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    I didn't think you wanted to bomb it, I am not either.
    But if it's for rock crawling you won't need that, if for a faster kind of wheeling you might.
    I am building a multipurpose off road and on road vehicle that I can drive to the trails and will be for dunes, snow, basically fast trails.
    For rocks I have my inline six that gets me 415 ft lbs of torque stock.
    And as for someone's suggestion to build it with on wastegated turbo, I guess you weren't looking for the right way but a different way and maybe even a cheaper way, right?
    /forums/images/graemlins/waytogo.gif
  11. BlueBlazer
    Feb 15, 2001
    1,940
    A smaller wastegated turbo will spool up quick and make decent boost at the high end without too much cost or trouble. I wish the turbo on my crew cab was an ATS with a wastegate so it would spool quicker. I would be more than willing to give up a few pounds at high rpm to gain some low end torque.
  12. jarheadk5
    Mar 6, 2000
    4,389
    PA
    Precisely what I'm doing. I don't have the luxury of a tow vehicle or a trailer, so it has to be streetable. Some of my wheeling will be done at altitude (Paragon in PA - don't know the exact alt. but it sure ain't sea level), and I've read the NA 6.2 gets to be a dog at altitude.
  13. tRustyK5
    Jul 23, 2000
    36,188
    1,396
    E-town baby!
    Moab is anywhere from 4000 to 6000 feet above sea level, and I only noticed a small drop in power when we were there. I live right on the west coast and maybe 30 feet above sea level, so I'm used to the max power my 6.2 will make...
    It's not as gutless as some people will lead you to believe, although having more with a turbo would be cool.
    Rene
  14. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    Hey my burb has the ATS turbo on it, are they all wastegated?
    I haven't had the chance to look at it yet since it wasn't running when I got it and now I will be looking into fixing it.
    Where is the wastegate usually on those?
    is it somewhere at the bottom?
  15. jarheadk5
    Mar 6, 2000
    4,389
    PA
    Really? Huh... I've heard that NA diesels in general lose quite a bit of power at altitude, but no personal experience of it. Guess the power drop isn't as bad as some people make it out to be.
    I drove M1008/9's around a bunch while in the Corps, so I know the NA 6.2 isn't totally gutless. If it was, I certainly wouldn't waste my time and $$ swapping out my TBI small-block for it.
    As far as "having more with a turbo would be cool" goes... Too much is just enough, right? /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif
  16. jarheadk5
    Mar 6, 2000
    4,389
    PA
    So, where would one look to find one of these ATS wastegated turbos? Would this be taken from a donor vehicle, or a purchase from ATS? Do you have a part # or an application to look for in a yard?
  17. tRustyK5
    Jul 23, 2000
    36,188
    1,396
    E-town baby!
    The turbo set-up on the 6.5 TD's is a wastegated turbo. I believe it's a GM8 and you see them relatively cheap on ebay now and then...usually as an assembly.
    I really don't know how those turbo's stack up against the ATS. The banks I've heard only starts making boost in the upper rpm's which seems useless to me.
    Rene
  18. BlueBlazer
    Feb 15, 2001
    1,940
    I believe all ATS turbos as well as the 6.5 turbos are wastegated. Im not sure exactly where it is on the turbine housing, but it should not be too hard to find.
  19. BlueBlazer
    Feb 15, 2001
    1,940
    You would have to call up ATS and see if you can still get turbos from them, and as was already mentioned the 6.5 turbos would probably work well.
  20. jarheadk5
    Mar 6, 2000
    4,389
    PA
    That's EXACTLY why I'm thinking small twins would be a better, more cost-effective all-around setup than a bigger single for what I want to do. The smaller turbines would require less hot-side energy to get spooled up and start providing manifold pressure. Faster spool-up at a lower RPM = /forums/images/graemlins/cool.gif /forums/images/graemlins/cool.gif
    After I do some more research on import boards and The Diesel Page, I think I'm gonna give this a shot. It's a long-term project anyway so why not... As long as I monitor upstream EGT's and boost pressure real closely (along with the other stuff) I suppose I can avoid meltdowns.
