twisted axel
Discussion in 'The Garage' started by yellowmoon, Sep 26, 2002.
  1. yellowmoon
    yellowmoon Registered Member
    Dec 30, 2001
    94
    Modesto Ca.
    Ok, what the hell, I twisted the differential loose from the axel housings. The tubes hold still and the pumkin twists up and down! Is this fairly common? /forums/images/icons/confused.gif
  2. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Not common, but not unheard of... The tubes are still there in good shape, just the rosette welds broke? </font color>
  3. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I did that to mine. For me that was the last straw w/ the 12B and I went to a 14FF. I rotated the right axle tube (along w/ previously cracking the center section and breaking off all the wheel lugs at 80mph). My pinion pointed to the sky and bent up the leaf springs on the left side. I was still able to drive it home (about 100mi)...I just took it real easy.
  4. yellowmoon
    Dec 30, 2001
    94
    Modesto Ca.
    Yep tubes just fine, think I'm going to have them welded up and see what happens.
  5. Impex
    Impex 1/2 ton status
    469
    Chandler, AZ
    on my 12bolt tubes stayed put, but the differential point towards the sky. so i upgraded to 14b /forums/images/icons/grin.gif
