Twisted splines on pitman shaft
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 79Beast, Aug 25, 2002.
  1. 79Beast
    79Beast 1/2 ton status
    Dec 9, 2001
    1,155
    Georgia
    I am running ORD crossover steering on my 79 K10 with 8" of lift and 44" swampers. My 2wd steering box came off of a 72 C10. It appears that I twisted the splines between the pitman arm ant the box. Has anyone else had this problem? Is it dangerous? TIA.
  2. Batmanjr
    Batmanjr 1/2 ton status
    Mar 23, 2001
    1,537
    Copperas Cove, Texas
    Never seen it, but that would make one hell of a wall trouphy!!! /forums/images/icons/cool.gif
  3. 79Beast
    Dec 9, 2001
    1,155
    Georgia
    Thanks, I take that as a compliment. I'm gonna run it until it becomes problematic. I'm surprised no one else has had this occur.
  4. Diesel Dan
    Diesel Dan 1/2 ton status
    Feb 27, 2002
    798
    Warren, Ohio
    I will be a problem when it snaps off!
    Replace it ASAP, consider it a safety hazarad. I have seen them twisted right off, splines stripped out and balls blown out of the rack/worm assmebly.
    I know the threads are heat treated and I believe the splines are as well, so if it is twisted it is cracked as well.
