twisting a 205
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Toledo, Mar 19, 2002.
  1. Toledo
    Toledo 1/2 ton status
    Dec 10, 2001
    207
    College Station, TX--DeRidder, LA
    How much can I clock my 205 before problems such as a lack of lubrication occur? lol
  2. 1bigk10
    1bigk10 1/2 ton status
    Dec 20, 2001
    151
    Medford Oregon
    I'm pretty sure that all you neeed to make sure of is to keep the bottom half of the idler gear imersed in gear oil to carry the oil up to the main drive gears.
  3. 1bigk10
    Dec 20, 2001
    151
    Medford Oregon
    You can use pipe fittings in the plug hole to run a tube up higher when rotating the t-case to kaeep the oil level where it covers the bottom half of the idler gear.
  4. 4GUNZ4X4Z
    4GUNZ4X4Z 1/2 ton status
    Aug 10, 2000
    3,459
    Mustang, Oklahoma
    Yep exactly what 1bigk10 said Thats what I did to my 203.
  5. jekbrown
    May 19, 2001
    45,030
    365
    Vancouver, WA, USA
    lol, i didnt even know you could clock a 205. Hmmm.. I will be getting high-angle drive shafts anyway... and need to make a crossmember also... maybe i should look into this. Anyone have pics?
    J
  6. Toledo
    Dec 10, 2001
    207
  7. 1bigk10
    Dec 20, 2001
    151
    Medford Oregon
    Damn that things bigger than mine and I thought mine was huge. I think its a 3/4 inch steel plumbing pipe you know the ones with threadon them use a 2" piece then a 90 degree elbow about a 4" piece a coupler and put your plug in the long end you can rotate the plug where it needs to go to keep te idler shaft wet. here was a write up on one of my magaznes can remember wich one but it was on a ford and they did the pipe thing.
  8. jekbrown
    May 19, 2001
    45,030
    365
    Vancouver, WA, USA
    hard to see it very well... /forums/images/icons/frown.gif anyone else have a pic of a clocked 205?
    J
