two bolts on transfer case brace wont come off?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by RyansRod, Feb 2, 2002.
  1. RyansRod
    RyansRod 1/2 ton status
    Jun 13, 2001
    118
    Bay area CA. USA
    Have an 84 K5 with NP208, Trying to get off two bolts that keep the transfer case brace on the transfer case. The brace bolted to the case and the engine block, but won't come off the TC. Are these bolts reverse thread or what their on there tight!
    Friends don't let friends drive fords
  2. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    Not reverse threaded, just the aluminum-steel interface/corrosion. Mine took some careful work with the "attitude adjuster" (4lb hand jack) then they came right out. Good luck to ya![​IMG]
    ......And knowing is half the battle
    <a target="_blank" href=http://pugsley.alloffroad.com>pugsley.alloffroad.com</a>
