Two fuel tanks on K5??
Discussion in 'The Garage' started by JHG, Oct 29, 2003.
  1. JHG
    JHG 1/2 ton status
    Jul 28, 2002
    129
    Iceland
    I have an 81 K5 with 31 gallon tank. Thats far from enough when I am traveling. I was wondering if somebody had put another tank in K5 /forums/images/graemlins/k5.gif?
    I was looking under my truck and I dont see where that tank could be /forums/images/graemlins/thinking.gif
    Jon H.
  2. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    i'm putting a second tank in mine. Kinda. Because of suspension mods, I can only get 20 gallon tank to fit in the factory location so I'm putting a 15 gallon in front of the factory front gas tank crossmember. I'm using large transfer tubes between the tanks and one sending unit in the rear tank and drawing fuel from the front tank only. It will act like one tank this way but will hold more fuel.
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    You have a couple of options. One is to replace the stock tank with a 45 gallon aftermarket tank. /forums/images/graemlins/eek.gif The other is to add 1 or 2 side tanks, which hold about 18 gallons each. /forums/images/graemlins/shocked.gif Check out www.aerotanks.com they're one of the places that makes aftermarket tanks.
  4. JHG
    JHG 1/2 ton status
    Jul 28, 2002
    129
    Iceland
    I dont like idea of having a side tanks. How do they hold up if somebody drive in the side of the truck? Perhaps they are ok, and I hope so, because that might be the best solution /forums/images/graemlins/smile.gif
    Thanks,
    Jon H.
  5. TONYP
    TONYP 1/2 ton status
    Aug 13, 2002
    2,116
    so cal
    I have one on each side....
