Two leaf springs cracked, dangerous!?!?!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by anatomiczero, Jan 24, 2002.
  1. anatomiczero
    anatomiczero 1/2 ton status
    Jun 26, 2001
    418
    Washington
    Well on the driver's side rear the middle 2 that run the whole lengh are broken (towards the rear they've split). Is this a big hazard or will it be ok?
    80' GMC Jimmy 4x4, 350-TH350-NP205
  2. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    Yeah, thats pretty bad. Mine broke right at the center pin and the ubolts were the only rusted things holding them together. While I was lucky and it got me home, I wouldn't suggest anyone drive with it like this.
    I started with nothing and I still have most of that left! - <a target="_blank" href=http://www.echobit.com:81/k5/> Pictures</a>
  3. anatomiczero
    Jun 26, 2001
    418
    Washington
    &lt;bump&gt;
  4. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Springs that are cracking like that are badly fatigued and I'll bet the rest have cracks you have not noticed (or soon will have). I would be finding some replacements. Now would be the time to ditch rear blocks for a spring lift, or get Ford Springs to run a Springer Suspension, go to a longer spring if you like (softer and flexier), etc.
    Russ
    85 K30 CUCV, 350 TBI, TH400, 205, D60/C14, 4.56 Locked, 4" lift, 42" tires
    Some day: massive cutting, shorter wb and rear overhang.
  5. anatomiczero
    Jun 26, 2001
    418
    Washington
    I'll probably replace them next week then.
