TWO QUESTIONS ABOUT MY WINDOWS
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by scrappyk5, Oct 14, 2002.
  1. scrappyk5
    scrappyk5 1/2 ton status
    Mar 17, 2002
    2,099
    virginia
    fist question is , why do my electric windows go up
    and down real slow , sometimes even stopping halfway?
    is this a common problem?
    the other question is , how can i put the rear window on the
    tailgate up with the tailgate open?
    i am tinting the windows and it would be easier this way
    thanks
  2. fulltopblazer
    fulltopblazer 1/2 ton status
    Aug 1, 2001
    484
    Altus,Oklahoma 73521
    The problem with your doorglasses could be several things
    1. weak motor
    2. felts wore out
    3. all the channels. rollers, and guides full of dirt and crap.
    take your door panel of and clean everything real good and relube evrything. You might check the voltage going to the motor. If everything is clean and it has a good 12v going to the motor and its still slow replace the motor.
    As for your backglass open the tailgate. Relatch the latches on each side and roll the window up BECAREFUL support the glass as you roll it up or your going to be picking it up off the floor in about a million little pieces /forums/images/graemlins/grin.gif hope this helps
