two questions here.
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by cybrfire, Dec 26, 2002.
  1. cybrfire
    Dec 15, 2002
    15,142
    568
    Iowa
    What do I need to move a 205 tcase from a 4 speed to a 400 trans. I imagine it was a SM465. This is a 1976 vintage if that makes a difference.
    Second, I read about alot of guys using 57" ford leaves in the rear with a shackle flip for the additional flex. What do these leaves come from and other than the lift that comes from the shackle flip is there any other height gains or reductions from the ford leaf packs? OK so that was more than two questions. /forums/images/graemlins/confused.gif
  2. 77fixer
    77fixer 1/2 ton status
    Nov 22, 2001
    464
    Meridian, ID 83646
    Check this out.
    ORD 205 page
    If you have any questions after reading that page, PM me, I did this swap with a 2wd 400.
    Brett /forums/images/graemlins/burb.gif
  3. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    Depending on what you use to mount up the 57's, you can get them to give you about 4 1/2" of lift with the shackle flip using 84-94 F150 4 leaf plus overload springs. Using 3 leaf plus overload gives you much less but I'd only suggest it with a truggy where the weight has been removed from the rear end.
  4. cybrfire
    Dec 15, 2002
    15,142
    568
    Iowa
    OK, that ought to about cover the t case question. Tons of info there. Sounds like the leafs won't do much lifting other than the shackle flip which is perfect. I am running a 4" block now. Going with the shackle flip and 57" springs will work perfectly. Thanks...
