two questions
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by KENNY, Jul 22, 2001.
  1. KENNY
    KENNY 1/2 ton status
    Dec 7, 2000
    292
    nyc
    I have an 84 with a 305 4spd, I have two questions. first, was under the truck which I use daily, and noticed two leaks one which is coming from the rear of the transfer case where the driveshaft part comes out. secondly the fuel line is leaking where the rubber extenions is (under passenger seat),tried to correct with new rubber and made worse , brittle lines. I've never bent lines before and not sure how to do it. how much should I expect to pay for this job. and the leaking transfer case? thanks
  2. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    I paid 4 bucks for the rear seal for the TC last weak at Kragen, which was interesting detailed in the Non-4x4 forum. Didn't stop the leak, so I'm thinking it's coming from the case halves. Wasn't not a hard job, except it broke my seal puller so I had to use a screwdriver, which is hard due to the aluminum case. Total time, 15 minutes.
    "I am Republican. Not a baby-killing, tree hugging, land grabbing, touchy feely, hypocrite wuss democrat!"
  3. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    If you order the hard fuel line from <a target="_blank" href=http://www.inlinetube.com>www.inlinetube.com</a> you should not have to much trouble installing it your self.
    '71 Blazer CST w/ a 400sbc, 4" lift, 36" Supper Swampers, and alot of rust
  4. KENNY
    Dec 7, 2000
    292
    nyc
    I would take that the lines come pre bent.. has anyone done this job. Is it difficult. the thing is I CAN'T FIT THE BLAZER IN my garage that leaves the driveway which is sloped downward.ie not very safe. which leave the street. I live in the city. plus i'm thinking that while i'm there i'm por 15 the fram where the rails lay first. the car has a minor gas leak which i can see cause the area is wet after driving. not safe i know not to mention wasted gas. how long can i leave this like it is while i wait for the lines. and another thing these lines are brittle from rust if i start hacking murphy's law is bound to take affect.
  5. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    I've heard if you fill the tube with sand or fine powdered dirt it won't kink when you bend it. Just rinse it out well!
    "My blazer may be slow, but it goes faster at higher speeds"
    <a target="_blank" href=http://community.webshots.com/user/blazerk5>http://community.webshots.com/user/blazerk5</a>
    Jim
  6. RESTORE89
    RESTORE89 1/2 ton status
    Jan 31, 2001
    548
    CHAS SC
    have the same leak, and replaced the seal, and still leaking, think the yoke is monkeyed up, but it is real easy to change the seal (even in the driveway)
    i personally find it very offensive to have a K5 refered tp as a "CAR"
    good luck with the fuel line, but i think i might try just cutting the hard line a little shorter, and increasing the length of the rubber. but then i have driven for extended periods with no rear brakes, so safety is not alwways as high a priority as some
    It needs a bigger motor.
    what's in it now?
    doen't matter it NEEDS A BIGGER MOTOR
    89 350tbi/700r4h/np208/4.11's
  7. shawnboy
    shawnboy 1/2 ton status
    Jun 22, 2001
    468
    Toronto, Canada, eh.
    you should be aware that depending on which tranny/transfer case you have that they have the possibility of being swapped around therefore 2 different seals, 2 different part numbers. I went through 4 seals, all from G.M., they were the ones with the long rubber seal, this using the serial # and G.M.s' parts book it should have worked. Didn't. Turns out the 350 seal fits my 700R4. Weird huh?
    Shawnboy
    If you are having too much fun it's probably illegal.
  8. RESTORE89
    Jan 31, 2001
    548
    CHAS SC
    ok now i am really confused
    the seal went into the houseing ok, but it still leaks around the shaft
    are you saying the rubber ring around the yoke may be to small???
    what's in it now?
  9. KENNY
    Dec 7, 2000
    292
    nyc
    Truck, TRUCK,TRUCK I MEAN TRUCK. IS THER ANY DANGER TO RIDING WITH LONGER LENGTH RUBBER ON MY TRUCK.
  10. Brian 89KBlazer
    Brian 89KBlazer 1/2 ton status
    779
    Ontario, Canada
    Further to what Shawnboy said; depending on the vehicle &amp; the previous owner; if there was one; the driveshaft may be the cause of the leaking seal. When I first got my 89, the owner gave me a spare shaft he had from a buddy who had an older Blazer. When I swapped it in with a new seal, it continued to leak. When I got a new Tom Woods shaft, the fit into the back of the t-case was MUCH tighter &amp; the leak stopped. My guess was that the seal was fine but the "free" shaft was not a good fit &amp; left room around the seal for a leak.
    Worth a look
    Brian
    89KBlazer
    Build it Right or Don't build it at all!!
  11. newyorkin
    newyorkin 1 ton status
    May 8, 2001
    16,555
    157
    Los Estados Unitos
    I don't see any danger in it, but make sure you get fuel injection hose, not just rubber hose, with two clamps at each connection. Fuel line hose won't decay from the petroleum based fuel running through it, while other hose will, very quickly. Fuel injection hose is also made to hold higher pressure's, although that's less of a concern than instant rot...
    You can run a lot of the fuel system through the correct grade rubber hose, but one thing you should be wary of: the sender unit at the gas tank. If your lines are that rotted, the sender probably is also at the top of the tank, which is roughly a $200 part. Don't mess with that one until you can afford to run out and grab the part in case you need it (and you may not need it).
    Man, too bad I have to get my truck and my wife's car inspected today, or I'd come out there and give you a hand while I'm off from work.
    For the seal, be very careful! I chipped my 208 output housing changing the seal. <a target="_blank" href=http://k5.8m.com/cgi-bin/i/images%5Cmisc%5CDSC01067.jpg>k5.8m.com/cgi-bin/i/images%5Cmisc%5CDSC01067.jpg</a> It still leaks, so I'm assuming it's the case halves, and when I get several hours altogether, I'm going to take it apart and reseal it.
    Ratch
    &lt;a target="_blank" href=http://k5.8m.com&gt;k5.8m.com&lt;/a&gt;
    **K5 - What more is there to life?**<P ID="edit"><FONT class="small">Edited by newyorkin on 07/23/01 08:05 AM.</FONT></P>
  12. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    I have a leak at teh back of my t-case as well. I cleaned everything real good at the car wash and drove it for a while. I found the leak was not coming from the rear seal of the t-case but rather from the yoke itself. I had a nice spray pattern on the bottom of the truck just above the end of the yoke/u-joint. I took it to a tranny shop to get their opinion. They said the cap in the middle of the yoke must be leaking. They recommended getting the cap re-welded or getting a new yoke. I am picking one up from a guy on here in OK Sunday. Will let you know how it is after replacement.
    I plan to replace the seal while I have the yoke out. Anyone have the different part nos for these seals?
    Brian
    Click to see <a target="_blank" href=http://tx85gmcguy.alloffroad.com> My 85 Jimmy </a>
