Two questions
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by kiley, Aug 19, 2001.
  1. kiley
    kiley Registered Member
    Mar 5, 2001
    87
    Salem, Oregon
    Question 1: What can I do to stop quicker? Currently the brakes are stock. I have a four inch lift and 33's.
    Question 2: Can rubbing be expected with 35" tires and a 4" lift?
  2. Esteban86K5
    Esteban86K5 1/2 ton status
    3,712
    Bakersfield, CA
    Q 1- convert your rears to disk.
    Q 2- Maybe while flexing.
    <font color=blue>Esteban</font color=blue>
    <font color=red>HAVE YOU EVER HEARD OF CHATA?</font color=red>
    <a target="_blank" href=http://coloradok5.com/gallery/Estebans-album>http://coloradok5.com/gallery/Estebans-album</a>
  3. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    First I would look into getting the stock brakes working good (test brake booster, pads, calipers, shoes, springs, etc..). I have stock brakes and it stoped fine with 33's (after all of the above was new). Now that I went to 36's it takes more pressure to stop but I can still lock them up.
    My 33's rubbed at the front of the rear fender when flexed up. With a little trimming my 36's only rub at the rear of the front wheel well (which I did not trim) when flexing. The worst offender is the "fang" area in front of the front tires. It rubbed when backing into my driveway before the trimming (w/ 36's).
    '71 Blazer CST w/ a 400sbc, 4" lift, 36" Supper Swampers, and alot of rust
  4. Esteban86K5
    3,712
    Bakersfield, CA
    Sure Triaged, you had to outdo me huh?[​IMG]
    BTW you might want to go to steel braided braklines also. I've heard of the stock rubber ones getting old and expanding a little every time you apply pressure. Steel braided ones won't expand, therefore all the pressure will get to your calipers, and wheel cylinders.
  5. bigblue
    bigblue 1/2 ton status
    Dec 6, 2000
    658
    southern california
    Answer to ? #1 - &gt; Install 1 ton brakes like I did. I stop better than any car i have ever owned...
    Answer to ? #2 - &gt; Yes, trim them fenders...
    Surfing is Life...
