Two Serious Questions.
Discussion in 'OffRoad Design' started by Batmanjr, Jul 26, 2001.
  1. Batmanjr
    Batmanjr 1/2 ton status
    Mar 23, 2001
    1,537
    Copperas Cove, Texas
    Has anyone ever heard of Klune-V IND. They make a product that goes inbetween the Trans and Transfer. It's supposed to reduce your gear ratio like a doubler. They say it's garanteed against breakage. (Yeah Right) What do you think of this product and is it worth it? Does it do the same thing as a doubler?
    Secondly: Does the Rock Ring work on a Mag-Hytec cover? Together?
  2. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    Yup, we've heard of Klune. They have a planetary gearbox that goes between the tranny and t-case, similar to our Doubler kit. Bulletproof I don't know about. I've heard of a couple of people having problems with them.
    Biggest difficulty with them is that they work best with a round bolt pattern and a lot of the GM stuff doesn't use a round pattern. So you end up having to buy adapters in addition to the $2K for the gearbox.
    I don't think any kind of rock ring will work on the mag cover, I'm not sure, but don't think so. Personally, I'm not a real fan of the rock ring, the 14 bolt has lousy clearance anyway, and the rings take up even more room. I had pretty good luck trimming the cover up high enough to where it wouldn't hang up.
    Making the world better, one truck at a time.
    SW-ORD
