Two things i really want
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by usmcanson, Apr 17, 2006.
  1. usmcanson
    usmcanson Registered Member
    Aug 30, 2005
    16
    havelock,nc
    Okay i think this is pretty common in the 87 k5... My power windows suck. If anyone has any information that would help me out as to switching to regular hand powered windows i would be very happy.
    Another question that i have is that someone had told me they put a serpentine pulley system on there 88 blazer....can this be done? If so i want to do it. Never got to see it but it would be great.
  2. dyeager535
    26,979
    On the window issue, depending on how pretty you want the truck to look, buying a set of manual doors is probably easier. If you have a common interior/exterior color scheme, you might get lucky, if your paint is still factory.
    You could do the swap, it's all a bolt in, but you'd essentially need two doors to donate all the guts anyways, might as well find a couple of nice doors and just bolt them on complete.
  3. blazinzuk
    blazinzuk Buzzbox voodoo Premium Member GMOTM Winner
    Dec 20, 2002
    17,412
    3,799
    Afton / Star Valley Wyoming
    You could replace the motors too. That and make sure everything is adjusted right and lubed up that would fix them too.
  4. 1985_K5_Silverado
    1985_K5_Silverado 1/2 ton status
    Dec 21, 2005
    984
    Corn Country
    Sometimes popping the door panels and just cleaning oxidation and corrosion of the electrical connections and switches, cleaning to dirt off the regulators, lubing up the pivots and that sort of thing can make a huge difference in the way of up/down speed. Mostly only your own labor time.
  5. rick88blaze
    rick88blaze 1/2 ton status
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    I did the manual swap on mine. It only took me part of an afternoon to do both doors. The manual window crank rod came right through the door panels where the switches were. I didn't have to cut or trim anything to put them in. Just make sure you get all of the bolts with the manual regulators. :D
    As far as teh serpentine swap goes, it is a bolt on, but you have to get the accessories from teh serp set too. You also have to move your alternator wires around and get the AC hoses for a '88 to '91 K5 and get a reverse flow water pump. That's a standard water pump on the trucks that came with a serp. setup. I'm sure there's more to it, but hopefully someone else will chime in about it.
    Rick
