two wire from 700R4 trans. What do they do? How about TV cable
Discussion in 'The Garage' started by cybrfire, Jul 20, 2003.
  1. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    I think the wires are blue and green. My transmission seems to be slipping. Would these wires be electronic lock up torque converter or something like that? This is an 85 GMC.
  2. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    Re: two wire from 700R4 trans. What do they do?
    ok new thought. Try this one. There is a cable coming from the trans to the carb. I thought this was a kick down cable but I believe it to be a TV cable now. For reasons I don't want to get into, I can't hook this up yet. Could or would this cause some shifting and slipping problems? I have read discussion on the TV cable before but don't know what it does. Any help here would be appreciated.
  3. angrysnowplow
    angrysnowplow 1/2 ton status
    Jan 8, 2002
    502
    MA
    If it is a TV cable, STOP DRIVING IT!!! I hear an incorrectly-adjusted (or not hooked up) TV will mess up that tranny post-haste!!!
    My understanding is that the TV cable controls line pressure in the tranny; affecting firmness of shifts, etc.
  4. 87BrnRsd
    87BrnRsd 1/2 ton status
    Apr 21, 2003
    2,457
    Boone, North Carolina
    Yes, just like what angrysnowplow said, STOP DRIVING IT!!!! The TV cable does affect line pressure, and leaving it out of adjustment, (or even unhooked in your case), will cause a premature failure of the transmission. If it is too far out of adjustment, then it can wear out the clutches in the tranny in a matter of a few miles. /forums/images/graemlins/blush.gif When it is hooked up, adjusting it one way will make it shift harder, and the other way will make it shift softer. It also affects when to upshift (like when yuo step on it), and when to downshift. BTW, why cant you hook it up right now???
    -Harrison
    P.S. Here is a good informative site about what the TV cable does, along with how to adjust it. TV Cable Adjustment
  5. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    I stopped driving it and did a hillbilly (calm down just an expression) hookup and that was the problem. I guess I need a new TV cable as mine no longer has an end on it that can be trusted. All frayed. Thanks guys.
  6. 87BrnRsd
    Apr 21, 2003
    2,457
    No Problem. /forums/images/graemlins/thumb.gif
    -Harrison
