Type F trans fluid
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by xnoahx, Sep 23, 2001.
  1. xnoahx
    xnoahx 1/2 ton status
    Oct 12, 2000
    817
    Ventura, CA 93004
    I hard that using Type F trans fluid is better than dexron III because the dexron is designed to slip for a smoother shift While the Type F helps make a firmer shift. Is this true?
    My 73 K5 <a target="_blank" href=http://www.geocities.com/xk5blazerx/73k5.htm>http://www.geocities.com/xk5blazerx/73k5.htm</a> 350/TH350/NP203, Q-jet, Edelbrock intake, Vortec heads, 4" lift, and 36" TSL's
  2. thatK30guy
    Jan 12, 2001
    32,076
    55
    Type F fluid is Ford stuff. They used this stuff on the older vehicles.
    Now adays, on the newer Fords, they use the Dexron fluids.
    Does that tell you something? [​IMG]
    <font color=red>I'm a "black top mudder"!!!</font color=red>
    <a target="_blank" href=http://coloradok5.com/gallery/thatK30guy>http://coloradok5.com/gallery/thatK30guy</a>
  3. xnoahx
    Oct 12, 2000
    817
    Ventura, CA 93004
    That doesnt really tell me anything, it would make sense that they use the dexron now because its made to slip and provide a smoother shift. Anyone else?
  4. mudddog91
    mudddog91 1/2 ton status
    Dec 28, 2000
    471
    north carolina
    Ive got a transmision overhaul and performance build up book that I bought at barnes and noble and Ive been running type F in my 1991 z-71 for about 3 years now and it makes a big difference.The way the book explains it is that the dexron IS designed to slip a little for a more comfortabl ride , plus dexron has got more anti corrosive and anti viscosity breakdown additives in it .Basically the book states that typeF and the expensive fluids like trick shift and such are the same stuff!Like I said Ive been running this for 3 years now and have been more than happy with the shift feel!!!!!1
  5. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Will the Type F fluid run hotter than the Dexron 3? Firmer shifts would be nice, but if it runs hotter it wouldn't be worth it to me because I run a 700R-4.
  6. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    I have heard the same thing. I know some people use type F fluid in auto transmissions built for racing.Type F is designed as a high friction fluid and should only be used in transmissions designed for this type of fluid. It probabally would provide firmer shifts.
    However I wouldn't put fluid designed for a ford in my GM trans.It is highly recomended by all lubricant manufactures not to do so.. They are designed to run on a fluid with the friction charestics that dexron has. I believe using type F will cause wear and durability problems.
    Dexron is good fluid. Even ford has been using it sence 1981. There must be a good reason no one uses type F fluid any more.
    If you want to firm up your shifts by changing fluid try TCI or B&amp;M trick shift trans fluid.
    <a target="_blank" href=http://coloradok5.com/gallery/Thunders-Blaze>http://coloradok5.com/gallery/Thunders-Blaze</a>
    <font color=blue>NEVADA: Where the pavement ends, and the West begins.</font color=blue>
  7. flcpl4fn
    flcpl4fn 1/2 ton status
    Jan 9, 2001
    194
    Florida
    i was told years ago when i had my 1975 blazer that the f-type fluid would hold up to hotter temps than the dexron III. and i didn't have a problem running it in my older truck
    '85 Jimmy in Jax, Fl
  8. xnoahx
    Oct 12, 2000
    817
    Ventura, CA 93004
    About it raising the trans temp, slippage causes heat and so if type F reduces slippage then it should run cooler.
  9. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    Thats a old school drag racing trick. These guys have been running Type F trans fluid in Glides/T350/T400 for years, it firms up the shift and that would also help the trans run cooler. I think it's compatible with the older G.M. auto transmission seals and valve bodys, but I'm not sure. I haven't heard anyone that runns Type F fluid in thire G.M. trannys say anything bad about it....BUT....
    I wouldn't run it in a 4 wheel drive on the street that HAS a shift kit installed allready. The combination of the shift kit AND Type F fluid, -might- be too aggresive, and the rest of the drive train would take a beating. (just my opinion)
    An average auto trans holds somewhere around 8-10 qts of ATF. A trans service only changes out about 4 qts.
    You can't go the other way around and run Dex.III in a old Ford C-4 or C-6. I've heard they slip to much and would self destruct with the Dex fluid.
    Dextron III can be run in ALL G.M. auto trannys. It is the same "100,000 mile" trany fluid used today. It's good stuff and seams to work as advertixzed from what I've seen.
    <font color=green>1012</font color=green>
    <font color=blue>Twiztid</font color=blue>
  10. Jason73K5
    Jason73K5 1/2 ton status
    592
    Fresno, Ca
    B&amp;M Trick Shift fluid is type F (just put a bottle in my Cougar), so if you can use it, then using any type F shouldn't hurt.
    73K-5: TBI350/TH-400/NP-203/14FF/D44
    Topless, doorless and no tailgate!
    Fresno, CA
  11. mudddog91
    Dec 28, 2000
    471
    north carolina
    There is a good reason people dont use type F fluid anymore,its because they design trannys to slip enough to provide driver comfort and because of its anticorrosive properties.Type F doesnt have these properties but it does have the firmer shift we are all looking for. B&amp;M's trick shift IS type F .TRY it and you wont go back to DEXron.I DIDNT notice an appreciable difference in temp after the swap so I cant confirm or deny..........
  12. Thunder
    Jul 20, 2000
    8,946
    Northeast Nevada
    Trick shift fluid is similar to type F. But it's additives allow it meet or excede all the Dexron or Mercon requirements. Type F does not meet these requirements.
    I'm not saying type F wont work in an older trans. I'v heard it works good in older TH350s. Also If your trans is rebuilt with heavy duty performance parts I dont think Type F would do any harm.
    But I would never put it in a newer stock trans like a 700r4, 4l60E, ect. They are designed for Dexron. Firming up the shifts on these tranys without modifing the clutch packs and other stuff inside usually results in damage.
  13. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    I have a th350 in my 73 pick up with a B&amp;M deep pan and they reccommend using type F fluid over the Dextron.
    See <a target="_blank" href=http://coloradok5.com/gallery/Waynes-Toy>Project Mighty Mouse</a> here.
    <font color=blue>Wayne<font color=blue>
    <font color=blue>Happy Trails<font color=blue>
