type of 4 link for front
Discussion in 'Center Of Gravity' started by rearsteer70k5, Mar 23, 2004.
  1. rearsteer70k5
    rearsteer70k5 Registered Member
    Jun 28, 2003
    33
    newark,cal bay area
    im building a 4 link for my truck. im going to do a triangulated 4 link in the rear. would this work in the front or should i go with the standard type 4 link front. any advantages or disadvantages with going triangulated.
    Thanks rick
  2. willyswanter
    willyswanter 1/2 ton status GMOTM Winner
    Dec 24, 2000
    2,690
    Bakersfield, CA
    Full hydro steering? If not then don't run a triangulated 4 link front. If you do your front axle will move straight up and down while your draglink creates bump steer. Run a 3 or 4 link with panhard bar and keep the panhard at the same angle and length as the draglink.
    If it is full hydro then go triangulated as long as you have no clearance issues in the front with items such as driveshafts, crossmembers, oil pans, etc.
  3. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    if you are going to go full hydro steering go with a triangulated 4-link. If you are going to keep that pesky drag-link use a 3-link with a Panhard bar. A 4-link plus a Panhard bar won't flex!(it turns the axle tube into a really thick swaybar /forums/images/graemlins/yikes.gif).
  4. rearsteer70k5
    Jun 28, 2003
    33
    newark,cal bay area
    i am going with full hydralic steering. thanks for all the anwser and one more question??? where can i find 1 1/4" heim joints. Thank you rick
