Type of screws?
Discussion in 'The Garage' started by lifethroughdeath, Oct 1, 2004.
  1. lifethroughdeath
    lifethroughdeath 1/2 ton status
    Jan 26, 2003
    300
    New Bedford, MA
    Hey guys, what would the best type of screw be for a fiberglass top as far as holding strength goes. I'm putting snaps in.
  2. dyeager535
    26,977
    I'm guessing you mean snaps like for a tonneau cover?
    For spoilers (and I assume the roof racks) GM used "well nuts". Threads that have a rubber plug around them. Push it into the hole, tighten the screw into it, and the plug seats against the fiberglass, holding it in place, while sealing it from water.
    You probably wouldn't want to use them on the thin parts of the shell, but where it is reinforced they work. Not sure how small you can get them either. A good hardware store will have them.
    Whatever you use, if you wheel the truck and plan on keeping it, I say seal the hole up good. If water gets into that back reinforced area, I guarantee the top will split at the seams eventually, from rust.
  3. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    I'd use a metal screw, I've seen wood screws break easily
  4. darkshadow
    darkshadow 1 ton status
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    not sure of your exact aplacation, but partacal board screws have a wide, leadg and hole very good!
  5. fad2blk99
    fad2blk99 1/2 ton status
    Feb 19, 2001
    860
    Charleston, SC
    ...stainless steel rivets.... dipped in 100% silicone sealant to lock out moisture. /forums/images/graemlins/thumb.gif
