Types of Motor Oil, 10W-30, or 20W-50
Discussion in 'The Garage' started by Looksback, Oct 17, 2002.
  1. Looksback
    Looksback 1/2 ton status
    Aug 12, 2002
    120
    Montana
    I have a '74 Custom C20, with a 292 inline 6, I was wondering would it help if I used 20W-50 instead of 10W-30 motor oil, when I have a heavy load, would it help with cooling?
    Thanks for the time
    LooksBack
  2. TrcksR4ME
    TrcksR4ME 1/2 ton status
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    It helps if it leaks oil... /forums/images/graemlins/smile.gif Not really sure on the difference between cooling, but it is heavy duty and will hold up better under severe use. All I run in my BB is 20w-50 synthetic blend, reasonable price, works well.
  3. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    I'm pretty sure that a heavier oil weight will not help your engine run cooler, at least not significantly. The only thing a heavier weight oil will do is stay "thicker" when the engine is running warm(like high RPM off-roading or towing). FWIW, I run 15w40 in the summer and 10w30 in the winter.
    Why do you ask? Are you having cooling issues(you shoudn't at this time of the year in MO.)?
    Fill us in a little better on what's going on, brother!! /forums/images/graemlins/smile.gif
  4. 87sm465np208
    87sm465np208 1/2 ton status
    Aug 28, 2002
    1,114
    illinois
    i use 20w-50, helps disperse heat in the engine compartment if you doni low rpm muddin, and stuff like that, also helps if your motor is older, this is what someone told me.
  5. Looksback
    Aug 12, 2002
    120
    Montana
    No I am not haveing cooling problems, but some of the stuff I heats the motor pretty good, such as hulling fire wood, gravel and other heavy loads, and I am here in the Rocky mountians and there is alot steep grades for long distances. But it is some thing I have been wondering about if heavyer oil would help with cooling.
    Thanks for the time
    LooksBack
  6. 87sm465np208
    Aug 28, 2002
    1,114
    illinois
    also with the chevys, i know on the small block v-8's chevy put the oil pump in the back of the motor, so the front rod bearings (#1 pison) get oil last when the engine is fired up, so you put some slightly heaveier oil in it, the oil sticks to the motor better, so when you start it up, its not so dry, and such, thats really cool you have the 292 |-6, i had an old 2wd F-100 ferd with a 4 speed OD /forums/images/graemlins/frown.gif, with the 300ci striaght 6, i loved that motor, didnt like the trans, 2nd and od were [censored] up, and it was a stick, and it was a gehtto beater i had to rev it all the way up in 1st and shift it to 3rd, that was a pain in the ass and i regret buying that truck, but it got me to my present truck, my 4x4 chevy /forums/images/graemlins/smile.gif.
  7. TrcksR4ME
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    Sounds like 20w-50 would work well for you then.
  8. balzackks84
    balzackks84 1/2 ton status GMOTM Winner
    Aug 22, 2002
    1,344
    portland, oregon
    When my motor started blowin a little oil past the rings I put 80-90 in the hog, purrs like a kitten /forums/images/graemlins/grin.gif j/k. I run 20-50 val max. Haven't had any problems with it thinning out when the temp gets up. I do have a little bit of a noisy lifter when I start it, im sure it doesn't help that. /forums/images/graemlins/frown.gif
  9. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,141
    14
    Bangor,Pa
    20 50 is a good thick oil and it will help keep your oiul pressure up as well as stick to the engine components better.i oinly run the 10w30 in my wifes ricer.it runs better on the thin stuff.but my chevy likes the 20w50 a lot better than the thin oil.
  10. 87sm465np208
    Aug 28, 2002
    1,114
    illinois
    thanks for the info trail king, im just glad that my uncle who was a machanic for mercedis for 10years, steered me in teh right direction by telling me to but the 20w50 in her. /forums/images/graemlins/laugh.gif
  11. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    I use 20-50w in my VW bus,beacuse of the performance engine. Plus I can only hold 4 qtz of oil. /forums/images/graemlins/eek.gif
    Cut's down the heat also.. /forums/images/graemlins/thumb.gif
  12. chulisohombre
    Apr 11, 2002
    4,141
    14
    Bangor,Pa
    no problem man.
