Typical Gas mileage
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by personaltrainer, Nov 9, 2004.
  1. personaltrainer
    personaltrainer 1/2 ton status
    Nov 4, 2004
    178
    Atlanta GA
    I've got a '86 Jimmy and I'm getting 8-11 MPG. 4bbl Holly, aluminum intake, cam, flowmasters.
    This sounds about right? /forums/images/graemlins/dunno.gif
    thanks
  2. 84k5
    84k5 1/2 ton status
    May 13, 2000
    2,949
    Dublin, CA
    I get about the same. The best thing to do is not keep track. /forums/images/graemlins/whistling.gif
  3. Poohbair
    Poohbair 1/2 ton status
    Jan 30, 2003
    2,139
    Ellensburg, WA
    I would help you out, but in the 3 yrs that I have owned my truck it has never had a speedo/odometer that worked. All I can tell you is at 8-11 I think you are getting better than me.
  4. mr_blasto
    mr_blasto 1/2 ton status
    Nov 8, 2004
    495
    Irvine, CA
    Bone stock on my '72 I get 7-8, even on the freeway with the top off, totally empty. I am trying to figure out solutions to get me in the double digit area... oooh how nice just 10 mpg would be /forums/images/graemlins/woot.gif- I don't ask for much.
  5. sickquad
    sickquad 1/2 ton status
    Jul 23, 2003
    785
    Ma
    I'm getting around 16 with overdrive.
  6. personaltrainer
    Nov 4, 2004
    178
    Atlanta GA
    Cool. Looks like my mileage is about average then - not a problem. I've been at this old truck game long enough to know it's gonna be bad - just wasn't sure how bad was normal!I'm gonna take the advise and stop keeping track!
  7. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    Don't think about it...it only hurts! I go to the gas station about 3 times a month, sometimes more and put in 100 litre(that's all the pump will serve at once) ((we're not allowed to use gallons anymore /forums/images/graemlins/angryfire.gif)) That 100 litres costs me about £85.00 (about $153.00). I just put it on the credit card and don't think about it. If I did worry about it, I'd have to buy a Honda /forums/images/graemlins/yikes.gif And we don't want that do we!! /forums/images/graemlins/rotfl.gif
  8. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Man you guys make me feel GREAT. Im lifted kinda big and get way better then that!
  9. rescuekrawler
    rescuekrawler Registered Member
    Nov 7, 2004
    28
    I only have 33's and get around 100miles to tank but it's not accurate b/c my speedo doesn't work either
  10. 79Beast
    79Beast 1/2 ton status
    Dec 9, 2001
    1,155
    Georgia
    Man, you guys have it bad. Maybe it's your driving style. I am lifted about 8" and run 44's with 5.13 gears, a 4 speed, and a 350 that I built. I got right at 10 mpg when I drove it to Tellico. I get 6-8 around town.
  11. mr_blasto
    Nov 8, 2004
    495
    Irvine, CA
    Correction: that was on one tank and i figured it was normal for me. During the last 5,000+ miles my mileage has actually been 8.73 mpg, and that is totally accurate - still bone stock with the top off, 350/th-350, 3.73. A little better /forums/images/graemlins/rolleyes.gif, but not much.
    Any ideas to make my mileage better. I can't afford fuel injection, but i am redoing the entire ignition system with msd stuff, going to electric fans instead of belt driven fans, adding headers and dual exhaust, and hoping to put on a 650 cfm carb with an edelbrock intake. I plan to do a few roadtrips so these will probably pay for themselves before too long. I'm thinking an LS1 swap is in order in the somewhat distant future, so I don't want to go crazy with this motor, and i want things that i can swap eventually. Any Ideas? /forums/images/graemlins/ears.gif
    SORRY 'BOUT THE HI-JACKED POST
  12. K5MONSTERCHEV
    Jan 27, 2003
    3,254
    Castro Valley, CA
    I think a LS1 is a lot more expensive then TPI conversion (not Edlebrock FI). I wouldnt waste money on MSD stuff. Just put in a HEI. OD would help.
  13. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    12-14MPG in a TBI rig (that was before the lift, 3.08's on 32's)
    I should see in the next month or so what 6" lift, 35's and 4.56's gets /forums/images/graemlins/ignore.gif
  14. jekquistk5
    jekquistk5 Weld nekid Premium Member GMOTM Winner
    Jan 18, 2004
    11,012
    842
    Pinckney, MI
    6" 35s 3.73's 350tbi stock arround 11.
  15. grundy99
    grundy99 1/2 ton status
    Sep 13, 2004
    389
    Loveland, CO
    6" lift
    35's that weigh 85lbs apiece
    4.10s
    Crate 350 with 4bbl Holley
    14 mpg no OD
    With 36" swampers that 115lbs a piece, 12 mpg
    /forums/images/graemlins/woot.gif /forums/images/graemlins/truck.gif
  16. gotmud77
    gotmud77 1/2 ton status
    Aug 4, 2003
    689
    bellefonte
    As far as i can tell i am getting about 15 or 16 mpg.
    350 edelbrock proflow,700r4,3.73,35"mt's.
    I was out wheelin two weeks ago and only used 7 gallons of gas all day. That was alot of different terrain, mud, rocks,hill climb. I was on and off the throttle alot and was expecting it to use more fuel then it did.
    All in all im very pleased with the pro flow kit.
