u-bolt length question... on D60...
Discussion in 'The Garage' started by jekbrown, May 11, 2002.
  1. jekbrown
    May 19, 2001
    45,030
    364
    Vancouver, WA, USA
    ok gang, bear with me here, I need some help. I am gonna go ahead and get the u-bolt kit I need for my D60 and I need to know what size bolts to get. My spring packs are 2.75" thick. Thats the thickness of a 4" spring + ORD zero rates. At any rate (no pun intended) anyone out there have a D60... and springs about that thick so they can tell me what size ubolts they are using? I mean, I would think it'd prolly be a set for like 8" springs... but I dunno for sure... and the axles arent installed yet so I can't exactly measure myself...
    any assistance would be, as always, appreciated!
    J
  2. Derf00
    Derf00 1/2 ton status
    Jul 25, 2000
    1,683
    Abilene, TX
    Just a suggestion, but wait until you have your axles and springs and have them made locally, and get them exactly the size you need. That's what I did and it worked out very nicely.
  3. jekbrown
    May 19, 2001
    45,030
    364
    Vancouver, WA, USA
    could do that, but the weekend I do the swap I wanna roll right through it as quickly as possible.... Id like to collect all the parts before hand so there are no hold-ups...
    J
  4. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    oregon spring will make them to any size you want while you wait takes about 15-20min
  5. jekbrown
    May 19, 2001
    45,030
    364
    Vancouver, WA, USA
    where is OR spring exactly?
    J
  6. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    You can also call ORD and tell them what you have and Stephen will hook you up. You will need 4" bolts since you have the zero rates. ORD sells the bolts in their D60 U bolt kit but they are not long enough for the zero rate but they should have ones that are long enough to include with your kit.
  7. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    Oregon Auto Spring Service Inc
    920 Southeast Stark Street, Portland, OR 97214
    (503) 234-9611
  8. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    jason they are the one's that did mine for me cost under $10 each and are made right then and there for you with all new washers and nuts /forums/images/icons/smile.gif you need 3 for the 60 what i would do is get everything together and find out how long you need them to be and have them made on friday then you are all set for the weekend install /forums/images/icons/smile.gif
  9. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    Paid $40 for 7 from ORD, exact fit.
