u-bolt measurements
Discussion in 'The Garage' started by SUPERSUB87, Dec 9, 2006.
  1. SUPERSUB87
    SUPERSUB87 1/2 ton status
    Oct 16, 2006
    463
    TEXAS
    how exactly do you measure a u-bolts?
    I need some longer u-bolts for my front. it has a 6" rough country lift and its a d-44. i need one inch longer ubolts so i can put a zero rate in the front.
    or if someone has done this and know what measurement i need that would be great. thanks
  2. burban89
    burban89 1/2 ton status
    Oct 16, 2006
    1,861
    Port Clinton, Ohio
  3. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    Length is measured from the inside of the U to the end of the bolt, the width is measured between the U and then you need to measure the diameter of the U-bolt.
  4. k30bb468
    k30bb468 1/2 ton status Premium Member
    Oct 2, 2004
    955
    NW Pennsylvania
