U Bolt plate
Discussion in 'The Garage' started by M-1028, Nov 25, 2006.
  1. M-1028
    M-1028 1/2 ton status
    Feb 2, 2005
    217
    Sealy Tx
    Can someone tell me who makes the u bolt plates for leaf springs that have a degree cut in them to match whatever degree shims your running. I keep breaking the bolts that hold the passenger side leaf spring, on a dana 60 (the bolts that thread into the housing). I also break leaf spring center pins alot and I am hoping the plates would help.
  2. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    What degree shim are you using? I have the factory degree shims on my front springs and i don't have any problems and i'm using the factory spring plates still. Are you torquing the U-bolts/bolts to the proper torque value? The torque is 110 ft. lbs. for a 5/8" U-bolt.
  3. M-1028
    Feb 2, 2005
    217
    Sealy Tx
    Well the first 2 yrs I had the truck lifted not a single problem, but here lately the truck has been wheeled really hard. Broke the bolts in the housing 3 times, now I'm changing the spring center pins all the way around for the 3rd time. I break them so bad my axles shift signifiganly and end my day. So to try and solve the problem I'm going to have a machine shop drill out all of the springs for 1/2" pins. I'm also getting all new U bolts and hardware, and new degree shims. I have seen the degreed plates and they have to help. When I tighten up the bolts in the housing I can see that they don't sit straigh.
  4. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    The breaking of center pins is usually because you don't have the U-bolts torqued properly. As far as the tapered spring plates they will cure the misalingment of the plates versus shims but you can also buy conical washers from McMaster Carr cheaper than buying tapered spring plates and they do the same thing. Do a search and you should find them on their website. Look for either conical washers or spherical washers.
  5. M-1028
    Feb 2, 2005
    217
    Sealy Tx
    Thanks, I'll check em out
  6. mrk5
    Apr 20, 2004
    12,341
    1,047
    Northern Colorado
    I agree with 4x4HIGH. I know after doing any work that requires removing the u-bolts I have to re-torque the u-bolts several times before they hold their torque. This is what the instructions said to do on the first lift I ever installed.
    I've always torqued mine to 150ft-lbs. Could have swore that's what the lift instructions said. And that was on 1/2ton 9/16" u-bolts.
    Although I don't run shims, but I did have tapered rear blocks for a while.
