U-bolt plates
Discussion in 'The Garage' started by lochenjons, Apr 18, 2007.
  1. lochenjons
    lochenjons 1/2 ton status
    Sep 13, 2006
    682
    Santa Cruz, CA
    I'm having trouble getting my u-bolt plate thing (what goes directly on top of the spring pack) onto the ubolts. I got it on fine on one side, a little difficult but no problem really. But now I just can't get them on on the other side. Any special technique or something? Or are they different between a 12b and a 14b? I didn't thik there was a difference and since the other side went on fine I still dont think there is. But still it seems like the plate should be longer? :confused:
  2. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,472
    5
    Olympia/Lacey, Washington
    uh yeah,,,,the 14b u-bolts are bigger, you need the right u-bolts for this to be installed correctly...:o
  3. lochenjons
    Sep 13, 2006
    682
    Santa Cruz, CA
    I have the right u-bolts! But what the ubolts go into, the ubolt plates, they wont go in on one side
  4. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,995
    134
    The axle tubes are different sizes between a 12 bolt and 14 bolt. That means they need different u bolts and different spring plates.
  5. garlicbreath
    garlicbreath 1/2 ton status
    May 17, 2003
    1,136
    Denver
    They are a PITA sometimes, get one end in and then squeze it with both hands, sometimes it's enough for the other to fall into the hole. That is if the plates are on top like mine.
    Otherwise, get a friend to help.
  6. lochenjons
    Sep 13, 2006
    682
    Santa Cruz, CA
    Ok...well I got everything to "work". It was a pain but it worked...but maybe it wasnt supposed to
  7. txfiremank5
    txfiremank5 1/2 ton status
    Jul 6, 2004
    3,105
    San Antonio, TX.
    Yeah, I don't know that I've ever installed any that didn't need to be mashed together a little while you're slipping the plate over 'em. If I'm especially tired.. or my hands are really greasy, I'll sometimes use a c-clamp and cheat a little.
  8. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    You are putting undue stress on the U-bolts by using the wrong plates. You should buy the correct plates and change them ASAP.
