u-bolt problems
Discussion in 'The Garage' started by nstarry, Nov 20, 2004.
  1. nstarry
    nstarry 1/2 ton status
    Feb 13, 2004
    349
    st.cloud minnesota
    this is probably a stupid question and it is plane as day!
    I pulled my front end from a 3/4 ton pickup, and set it under my truck and now i cant get the u-bolts to line back up with the plate. The u-bolts came off the axel so you would figure they would slide right back on but no! I slide them up the axel and they spread apart, does anyone have a easy way of getting these things on there? They are in perfect shape so i cant justify buying new ones.
  2. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    If you've got a big set of lock jaws, you can get em on. Just giver it a little squeeze to make it smaller.
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    This always happens with u bolts. They're not designed to be reused. Muffler clamps are the same way.
  4. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    The easiest way I know is using plastic wire ties .Squeeze the U bolts with your hand as you pull the ties tighter. Worked great a few times for me. You know you can link a couple together to make a long one.
  5. nstarry
    Feb 13, 2004
    349
    st.cloud minnesota
    zip ties crafty I ll try that thanks guys
  6. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    I smash them in a big vise to close them up.
  7. nstarry
    Feb 13, 2004
    349
    st.cloud minnesota
    I tried that they just spread back apart
  8. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I hit that problem putting the axle back under the project and I found something I should of known .........the springplates are proprietary to the side they came off of , they are left and right , the long u-bolt for next to the pumpkin only goes into the wider bolt pattern of the passenger side springplate . Maybe you have them backwards /forums/images/graemlins/k5.gif /forums/images/graemlins/k5.gif
  9. divorced
    Jul 20, 2004
    5,115
    I smash them farther than they need to be so that when they spring back they will be the right size. When they are in the vise I smash them until the ends are only a couple inches apart. Be carefull not to damage the threads. Try a few times with more pressure each time so that you don't go to far. If you do go too far, put the nuts on the end of the bolt to protect the threads and using two long pipes you can open it back up by standing on one and lifting the other
  10. diesel4me
    Jul 24, 2003
    17,537
    923
    Massachussetts
    I've used hose clamps to pull the u-bolts closer so they will go thru the spring plates--its tedious,but it works.I put two large clamps together to make them big enough to work.A C-clamp or the welders vise grip thing work well too. /forums/images/graemlins/crazy.gif
  11. nstarry
    Feb 13, 2004
    349
    st.cloud minnesota
    ya I didnt squeeze that far didnt know they would take that i ll try thet /forums/images/graemlins/thumb.gif
