U-bolt question - need response asap!!!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by shupach, Oct 20, 2001.
  1. shupach
    shupach 1/2 ton status
    Dec 28, 2000
    648
    Dallas, TX
    does anyone know the specs on ubolts for a 14 bolt FF and a D60? they both have 456 gears and were out of forest service trucks. any help would be appreciated.
    thanks,
    phill
  2. morphed86k10
    morphed86k10 1/2 ton status
    Jun 25, 2001
    463
    Reno Nevada
    this is really an application specific question. I believe the u bolt inner diameter needs to be 3.5 inches for te 14bolt, and usually of 5/8ths stock I believe. Length depends on the suspension. As long as the bolts are long enough to clear spring pack and (possibly) block, you'll be fine. In my case it took some 10 inch long bolts. I;m not sure on the D60 though.
  3. shupach
    Dec 28, 2000
    648
    Dallas, TX
    thanks, ya i need thickness and stuff, i dont care bout length
    phill
  4. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
    That is correct I just bought 4 from napa... 22 a piece...
  5. tRustyK5
    Jul 23, 2000
    36,169
    1,372
    E-town baby!
    14 bolt tube diameter is 3 3/8" not 3 1/2"...
    Rene
    <a target="_blank" href=http://coloradok5.com/gallery/project_T2> tRusty pics...</a>
  6. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    Not sure on the size for the 60 and I just finished bolting mine in a couple of hours ago.[​IMG] I can tell you the 60 uses 2 u bolts on the driver side that are the same and on the pass side it has 1 u bolt that is a different size then the driver side and then it will have 2 studs with nuts on the inside of the passenger side which can be replaced with bolts instead. BTW I got my u-bolt kit from ORD which included the 2 bolts.
    See <a target="_blank" href=http://coloradok5.com/gallery/Waynes-Toy>Project Mighty Mouse</a> here.
    <font color=blue>Wayne<font color=blue>
    <font color=blue>Happy Trails<font color=blue>
  7. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I 2nd that, my 14 SF was also 3 3/8".
    Tim
