U-bolt question?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by dasanii19, Mar 30, 2007.
  1. dasanii19
    dasanii19 1/2 ton status
    Oct 11, 2006
    344
    NV
    Simple question, what type and grade nuts do you use on your leaf spring U bolts? I bought 8, grade #8 nylocks for my fronts with washers and it was like $30.
    Is it necesary to run grade 8 nylock nuts on my U bolts? Im asking because I still have to do my rear leaf springs and if I dont have to spend $30 on grade 8 nylocks nuts that would be great..
  2. dasanii19
    Oct 11, 2006
    344
    NV
    Shoud I just use grade 5 regular nuts with a lock washer and a flat washer?
    Or grade 5 nylock nut with just a flat washer?
  3. justiz00
    justiz00 Registered Member
    Dec 11, 2006
    83
    Central Texas
    Im more of a top lock locking nut guy (plus they are only $.50 each). They are the ones that have the end ovaled to lock. Hold up better if you have to pull them on and off.
  4. sweetk30
    Nov 1, 2004
    25,537
    535
    horseheads , ny 14845
    never had problems with spring shop bent ubolts and hardened flat washers and std nuts thay give me. always up grade to 5/8 rod if possible it does fit in gm spring plates and hold better.
