u bolt replacement
Discussion in 'The Garage' started by kyser_soze, Apr 10, 2006.
  1. kyser_soze
    kyser_soze 1/2 ton status
    Sep 4, 2004
    3,180
    KC Missouri
    I am going to a shackle flip and a zero rate block to remove the rear blocks.
    I will need to replace the length of the u bolts. Does anyone know where I can get the correct length u bolts?
  2. MattK
    MattK 1/2 ton status
    Jan 12, 2005
    1,713
    Dallas, TX
    if you wanna go local, trailer and spring shops will have em. offroaddesign.com also has em i believe.
  3. sweetk30
    Nov 1, 2004
    25,536
    533
    horseheads , ny 14845
    axle tube dia for round bend. then add the tube dia + pack thickness+ zero rate+ top plate and nut thickness this will give you the length of the legs on the ubolt.
    so example : 3" tube = 3" round bend
    ...............: 3" tube +2.5" pack+ 1" zero +1/4 top plate+ 3/4 tall nut with washer=7.5 " legs.
    so 3" round bend and 7.5 leg ubolt will be waht you ask for . and i always go 5/8 rod for the size and it is grd 8 over the smaller rods that are grd 5.
