u bolt size 14 bolt ff
Discussion in 'The Garage' started by dammit32, Sep 28, 2002.
  1. dammit32
    dammit32 1/2 ton status
    Jul 20, 2002
    365
    Maine
    swapping and the parts store doesnt know the axle tube size for my 78 3/4 ton 14 bolt ff...anyone help?
  2. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    Axle tube size is 3 3/8". I believe you will need 3 1/2"x 8"x 5/8". Those are for stock size. If you have lift blocks, adjust the length accordingly.
  3. thatK30guy
    Jan 12, 2001
    32,076
    55
    What outlaw said.../forums/images/icons/wink.gif
  4. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,141
    14
    Bangor,Pa
    yeah what they said.lol
  5. 4X4HIGH
    Dec 14, 2001
    22,063
    71
    Pleasanton, CA.
    Why would you say to use a 3 1/2" U-bolt if the housing is 3 3/8"?
  6. BlueOx
    BlueOx 1/2 ton status
    Aug 6, 2000
    239
    Houston, Tx
    If the axle is 3 3/8" you would need an 1/8" more to clear the axle housing unless you planned to hammer it on. The extra 1/8" would make the size 3 1/2". Not trying to sound like an a$$ just letting you know.
    Charles
  7. outlaw612
    Feb 11, 2001
    2,342
    If you use the same size as the axle tube, it will spread the u-bolt slightly ang youll never be able to get the spring plate over the u-bolts.
  8. 4X4HIGH
    Dec 14, 2001
    22,063
    71
    Pleasanton, CA.
    When I swapped in my 14bff I used the proper size u-bolts of 3 3/8" and it works just perfect. If you use a larger u-bolt I can see how you would have to squeeze it together to go through the spring plate and that isn't correct. The factory U-bolts that I removed from the donor truck were also 3 3/8".
  9. outlaw612
    Feb 11, 2001
    2,342
    Maybe just a little difference from brand to brand. I know the 2 times I have done an axle swap I had to buy a 3 1/2" u-bolt be cause by the time I got the 3 3/8 over the axle it was spread way to far to fit in the spring plate. I buy my u-bolts from a farm store here locally. The 3" from the same company works fine on the front.(D44) /forums/images/icons/confused.gif
