u-bolt size ? *updated*
Discussion in 'OffRoad Design' started by JIMs70K25, Jan 18, 2003.
  1. JIMs70K25
    JIMs70K25 1/2 ton status
    Dec 31, 2001
    524
    Chesapeake, VA
    I was going to order some longer u-bolts, but I want to make sure I state the size properly. How would I go about that? State axle tube diameter and the overall length from bottom of "U" to end of threads? What about cross section of material? Always about 9/16"?
    Steve, I need a price for 4 u-bolts 3"x11" w/ washers and nuts. Thanks,
  2. JIMs70K25
    Dec 31, 2001
    524
    Chesapeake, VA
  3. morphed86k10
    morphed86k10 1/2 ton status
    Jun 25, 2001
    463
    Reno Nevada
    all I did when I went to my local spring shop was the diameter of the axle tube and the distance from the bottom side of the axle to the spring plate. They selected the stock, which happened to be the same size as most every ubolt I've seen.
  4. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    Basically, dia, length and axle tube size will do it.
    Ubolt kits are $38.00, we should be able to get one close to what you need off the shelf.
