u bolt size
Discussion in 'The Garage' started by poolcues, Sep 28, 2006.
  1. poolcues
    poolcues 1/2 ton status
    Dec 13, 2004
    232
    Charlotte,NC
    does any one know the inside diameter and bolt size ( 9/16 etc. )for u bolts on a 14 SF rear and 10 bolt front. i believe it's a 7/16 bolt with an inside diameter of 3 1/4 " for the rear and 7/16 bolt with a 3" diameter for the front.
    just looking to double check.
    thanks
  2. y5mgisi
    y5mgisi 1 ton status
    Aug 11, 2002
    17,156
    247
    Portland Oregon
    the front is 5/8" with 3 of the u bolts being 3" diameter and the other one being 3.5" diameter.
  3. poolcues
    Dec 13, 2004
    232
    Charlotte,NC
    i appreciate the info. you're right. i got off my lazy @$$ and went and measured them!!:D
  4. thatK30guy
    Jan 12, 2001
    32,076
    55
    Actually, the 14FF and SF tubes are closer to 3 3/8" diameter.
  5. sweetk30
    Nov 1, 2004
    25,526
    526
    horseheads , ny 14845
    upgrade all to 5/8. your better off. better strength rod.
  6. Cajun4x4
    Cajun4x4 1/2 ton status
    Oct 17, 2005
    889
    Lafayette, LA
    i went to the spring shop the other day and they said they couldnt do 3 3/8"... only 3 1/4 or 3 1/2 :dunno:
  7. yoshisv
    yoshisv 1/2 ton status
    Feb 19, 2006
    266
    Hartsville, Tennessee
    I bought some last week for a 14ff. They were 5/8 by 3 1/2 I.D
  8. sweetk30
    Nov 1, 2004
    25,526
    526
    thay just dont want to spend 100 bucks on a new die to bend them. :D
  9. Cajun4x4
    Oct 17, 2005
    889
    Lafayette, LA
    well yea, but should i look elsewhere for some or is one of the available choices acceptable?
  10. sweetk30
    Nov 1, 2004
    25,526
    526
    90% get away with the 3.5. but make sure you tighten the he!! out of the nuts and recheck the nuts at least 1 time. when you run the nut down it will pull the ubolt up as close as possible.
    if you are a perfectionest. get the 3 3/8 bend.
