U bolt source?
Discussion in 'The Garage' started by Geargrinder, Sep 5, 2005.
  1. Geargrinder
    Geargrinder 1/2 ton status
    Jan 21, 2005
    258
    Medford Oregon
    I have everything I need to but on my 6" lift, except U bolts to fit my SF14B (this was on a 1/2T before)
    Any one know where I can get JUST U bolts long enough for 6" blocks that will fit the SF14B tubes? :1zhelp:
    P.S. did a serch, but it will not serch for "U bolts" just "bolts" :doah:
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    14 bolt semi floater tubes are only 3" same as a 10 bolt, last I checked anyway...
  3. Geargrinder
    Jan 21, 2005
    258
    Medford Oregon
    Well...
    I haven't put a calipper on them yet, but they sure look bigger :crazy: I will go out and look and see right now :rolleyes:
    Just mesured, I got 3" even on the 10B, and 3.325" on 14SF.
  4. jeeptuff
    jeeptuff 1/2 ton status
    Aug 22, 2005
    158
    Arlington, WA
    That is correct, the 14B does have a bigger axle tube diameter than the 10 and 12 bolts.
  5. jeeptuff
    Aug 22, 2005
    158
    Arlington, WA
  6. bigjbear
    Feb 18, 2000
    13,970
    449
    Marietta GA
    Try a local driveline shop. That's where i get mine.
  7. Geargrinder
    Jan 21, 2005
    258
    Medford Oregon
    Not a bad idea, I'll call around and see what I find.
  8. thor
    thor 1/2 ton status
    Aug 20, 2003
    512
    Wa
  9. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
  10. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,075
    486
    Grand Rapids area
    You might have a hard time finding U-bolts INTENDED for 6" blocks and there is probably a good reason for this :rolleyes: . You might want to re-think that plan, but if you're set on it, a local drivetrain shop should be able to sell them to you OR have them made up custom.
    The axle tube diameter on the 14SF is the same as the 14FF. Just say 3/4-ton and you should get the right thing.
  11. Geargrinder
    Jan 21, 2005
    258
    Medford Oregon
    I knew that this would pop up @ some point :rolleyes:
    The blocks are a temp. fix ;) I haven't commited to what I'll do with the rear for the 6" of lift yet :crazy: I know I don't want 6" springs because of the ride quality, not sure if I'm gona go SF & 0 rate's, 2"spring & SF, ect., ect. :o
  12. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    I go to my local OTR truck repair facility, they custom make ubolts any dia, length while-u-wait.
