U-bolt torque specs
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by kpanza, Aug 21, 2001.
  1. kpanza
    kpanza 1/2 ton status
    Dec 8, 2000
    1,579
    Lake Forest, Orange County, California
    Just wondering what most of you use for a torque setting on your u-bolts? I have heard of wildly fluctuating numbers here, and I can't seem to find a definitive answer yet. Is it the 90 lbs someone told me, or all the way to 150lbs another person swears by? I think 150 would be excessive, but I did 100 last night after changing shims and it seemed like it might need a bit more? By the way, this was on the rear 14 bolt if that makes any difference (doubt it will) with quality Deaver made u-bolts...
  2. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    I torque mine to 140. Duno why I do, that is just they way i've done it. Someone somewere must have planted that number in my head years ago.......
    <a target="_blank" href=http://www.geocities.com/baja/5099>www.geocities.com/baja/5099</a>
  3. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    RFT![​IMG]
    Haynes says 150, lift kit said 110-120. So I go happy medium 130 ish. But RFT!!!!
    Just say no to crack(s)
    <a target="_blank" href=http://www.nashvillek5.freeservers.com>www.nashvillek5.freeservers.com</a>
  4. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    Whatever the value, always remember to retorque after initial 200 miles or so and/or after heavy wheeling.
    There is a Right way, a Wrong way, and then there is My way. The latter is usually the most fun! [​IMG]
  5. kpanza
    Dec 8, 2000
    1,579
    Well, I guess I will go with about 130 then. Anyone else have a number they always use?
  6. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    150 here...........again, someone planted that number in my head years ago...........
    <font color=blue>'79 ONE TON TPI K5 - See it at---&gt;<a target="_blank" href=http://www.blazzinor.rockcrawler.com>www.blazzinor.rockcrawler.com</a>
  7. RaisedK5
    RaisedK5 1/2 ton status
    932
    Long Beach, CA
    I think my factory manual says 140, but the lift kit did say 110, i usually go with the factory, unless i'm feeling weak.
    Leland aka RaisedK5
    "Of all the things I've lost, I think I miss my mind the most!"
    "Are the voices in my head bothering you?
  8. 86K5TrailBlazer
    86K5TrailBlazer 1/2 ton status
    Apr 24, 2001
    436
    Orange,CA
    I also do 140 lbs, just from friends oh yeah and Haynes too
  9. DMK
    DMK 1/2 ton status
    Feb 20, 2000
    757
    CINCINNATI, OH
    My 78 shop manual says 140 front and 150 rear.
