U-bolt TQ on 10B rear?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by jarheadk5, Jan 10, 2004.
  1. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    Can't find my Haynes book right now, and the 300 search results I looked at didn't help me, so...
    What's the torque for the u-bolts on a 10B rear axle?
    -I'm referring to the u-bolts that hold the axle under the leaf spring.
  2. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    "until tight"
    but seriously i used my 1/2" impact and hammered them down until they're tight.. criss cross pattern to make sure they're all torqued the same..
  3. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    I ran mine up to 130 ftlbs.
  4. btolenti
    btolenti 1/2 ton status
    Sep 28, 2003
    644
    Gilroy, CA
    WOAH! Won't that deform the U-joint caps!?!?!??!
  5. rick88blaze
    rick88blaze 1/2 ton status
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    I think they are talking about the axle u bolts. /forums/images/graemlins/grin.gif
  6. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    If you think you can get 130 ftlbs out of a 5/16" bolt all the power to you. /forums/images/graemlins/rotfl.gif Actually, very little pressure is put on the universal cap by the strap. In fact, I've been known to use little pieces of aluminum to put more pressure on the cap.
  7. Okiemuddog
    Okiemuddog 1/2 ton status
    Mar 3, 2003
    1,260
    Guthrie, Oklahoma
    Okay, clear this up, are you talking about the u-joint strap or the u-bolts that hold the axle to the spring? /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif
  8. TxK5Blazer
    TxK5Blazer 1/2 ton status
    Aug 13, 2000
    593
    Floresville, Tx
    if I remember right it is like 15ft/lbs
  9. btolenti
    Sep 28, 2003
    644
    Gilroy, CA
    Oops Sorry....I didn't think he was talking about the axle to leaf U-bolts....
  10. Confedneck
    Nov 1, 2002
    5,236
    leaf spring u-bolts, not u-joint straps, i believe..
  11. jarheadk5
    Mar 6, 2000
    4,389
    PA
    U-bolts that hold the axle under the leaf spring.
    Sorry... After re-reading what I wrote, I realized it's not clear what I'm asking.
  12. rick88blaze
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    yeah, 130 ft lbs. would be a little much on the u joint straps. /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
  13. TxK5Blazer
    Aug 13, 2000
    593
    Floresville, Tx
    If you are looking for u bolt torque on the rear axle it is 125lbs/ft on the rear and 150lbs/ft on the front ...Jason
