U-bolt widths
Discussion in 'The Garage' started by K5thatShmobs, Feb 24, 2003.
  1. K5thatShmobs
    K5thatShmobs 1/2 ton status
    Sep 27, 2001
    353
    San Luis Obispo, CA
    It may be a stupid question, but I want to make sure.
    What is the u-bolt width, inside to inside, for a full floater 14 bolt from an '86 one ton?
    AND
    Of the three u-bolts on a front 60, are the two smaller ones 3.25" inside to inside and the bigger one 4" inside to inside?
  2. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Don't know about the D60, but the u-bolt inside-to-inside measurement (outside diameter of axle tube) for the 14 bolt is 3 3/8"
  3. K5thatShmobs
    Sep 27, 2001
    353
    San Luis Obispo, CA
    Alright I did a little search after the fact and saw that a few times, that the 14 bolt's tube is 3 3/8". Anybody on the 60 specs?
    Also, where is a good place to get out of the ordinary sized u bolts?
  4. RedBrute
    RedBrute 1/2 ton status
    Sep 22, 2002
    346
    Southern tier New York
    I just measured my D60 ubolts. the big one measures 4.125 or 4 and 1/8 inch, the drivers side ubolts measure 3.125 or 3 and 1/8 inches. Both are inside measurements. I'd guess ORD could get these for you if there is no spring shop local to you.
