U-bolt ?
Discussion in 'The Garage' started by Never Satisfied, Feb 23, 2007.
  1. Never Satisfied
    Never Satisfied 1/2 ton status
    Aug 21, 2005
    709
    Lafayette, Indiana
    Hey guys I have just bought some 4" lift springs for my K-5 and need to know what size u-bolts to buy to put them in. The truck has stock springs with 4" blocks now so they won't work. Any help would be greatly appreciated. Thanks
  2. K5Greek
    K5Greek 1/2 ton status
    Nov 25, 2005
    2,054
    Vineland, NJ
    you should be able to use the same ubolts...
  3. Never Satisfied
    Aug 21, 2005
    709
    Lafayette, Indiana
    I don't see how, the bolts that are on there now are for a 4" lift block. The threads only go down about 1/2" below the plate on top of the spring. When I remove the 4" block and put the 4" lift spring in, they will be too long.
  4. W7NB
    W7NB 1/2 ton status
    Nov 9, 2006
    716
    Springtucky, OR
    You should be able to pick up U-Bolts at the local parts house - Just get stock Chevy (3 1/4"?) u-bolts, as the thickness on the spring packs are close to equal. Most parts houses have the stock bolts with fresh nuts (be nice) in a package deal.
  5. Never Satisfied
    Aug 21, 2005
    709
    Lafayette, Indiana
    Out of the 4 places I called, the only one that had anything in stock wanted to know the specs before they could help me. I know the tube size, but I needed to know the stock length and diameter sizes. Seems like nobody at the parts houses has the knowledge like the good old days.
  6. vortec
    vortec 1/2 ton status
    Jul 22, 2004
    1,472
    fort worth, texas
    they can't figure out what fits a 10 bolt, 14 bolt, etc? man, that place really is useless.
    i called a place the other day and said "hey. can you tell me the price for a 12V 30amp single-pole single-throw relay?" the guy froze up. after a few seconds he said "sir, i don't know what that is." at least he admitted it instead of trying to bs his way around it, but i'm not impressed with parts houses, today.
  7. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    :ignore: :weld: :shame:
    :doah:
  8. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    Did hell freeze over?
  9. W7NB
    W7NB 1/2 ton status
    Nov 9, 2006
    716
    Springtucky, OR
    I had a set of stockers i the garage. They measure 3.125 inch ID by 8 inch overall. Hope that helps!
  10. K5Greek
    Nov 25, 2005
    2,054
    Vineland, NJ
    yep i realized the error of my ways... but i was thinking that he wanted new ones becuase the springs would make it longer or something......
  11. Never Satisfied
    Aug 21, 2005
    709
    Lafayette, Indiana
    It's all good ;) .
    Thanks W7NB, that's really what I was looking for :waytogo:
  12. 5trucks
    5trucks 1/2 ton status
    Aug 12, 2005
    169
    Yuma Az.
    I have some that i had made. Got them 1" longer in case i went with the zero rates. Put them on and now i am going 14bolt. If you want them plus the nuts i'll get them to you for $20 plus the ride. I paid $17.50 each. Let me know. I assume you need these for a 12 bolt?
