U bolts and Spring plates for a 14FF
Discussion in 'OffRoad Design' started by Hossbaby50, Apr 16, 2002.
  1. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Hey Stephen,
    Do you guys carry these, and if so how much? I need ubolts for a 14bff that will fit springs with a zero rate, and an add a leaf in the pack.
    Also, what do new spring pack pins cost, and degree shims also. I put in the 1" zero rate, and I got a vibe now. I lowered the tcase 1/2" and it is alittle better, but would a 2-4 degree shim solve my problem? Thanks
    Harley
  2. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    We do have the plates and bolts, together they're called a ubolt reversal (reverses the square ubolts on a 1-ton) for $60.00. Our standard size ubolts should be long enough, they have a good bit of extra thread on them.
    We can get the Rancho 2.5 degree shims but that's about it. I don't have any here but can get them in.
    Just measure up the angles to try to match them, that's about all you can do with it. Just guessing but I think 4 degrees is going to be pretty close.
  3. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    Thanks Stephen. I will probably be ordering the ubolt reversal kit then pretty soon.
    Also what would a set of new center pins cost me? If I add the shim I will need new pins.
    Harley
