U-Bolts and Spring Plates.
Discussion in 'The Garage' started by colbystephens, Nov 16, 2005.
  1. colbystephens
    colbystephens 1 ton status GMOTM Winner
    Feb 24, 2005
    10,924
    20
    Oregon
    ok. so i know this question has been asked before and i've done a ton of research, but for some reason i cannot seem to explain what i want to have made in such a way that a company can make these for me. none of the places i've called seem to get it! i don't understand why this, a very simple concept, is so hard. :mad: can someone who has the following configuration please tell me exactly what i need to say to get these parts.
    i have a 14bolt ff rearend and D44 front end out of a '78 suburban. i have procomp 4" lift springs. axle tube diameters are 3 3/8" for the 14bolt and 3" for the D44. My spring packs are 2.5" wide. My rear spring pack is 2 3/4" thick. I don't know the thickness on the front, but that it is certainly not as thick. I can see how not knowing this part might be a problem, but why can't they just make the threaded part a bit longer just to compensate and i can spend some time hacking off any excess bolt. (BTW my truck is an hour away from me, otherwise i would just measure the front springs. I don't happen to trust the measurements given to me by the person who owns the place where my truck is sitting.) Just for the record, i have 4" Procomp lift springs front and rear.
    So, can someone please tell me what I need to do?
    colby
  2. redneckdude
    redneckdude 1/2 ton status
    Feb 21, 2004
    578
    Augusta, GA
    when i ordered U-bolts, the company i got them from (carrier spring services i believe) just asked the basic questions...diameter of the bolts needed (9/16" atleast), the tube size, and length overall of the bolts. I just measured the length of my stock ubolts with a tape measure (you can use one of those cloth ones or whatever, a soft one to follow the bolt and get it pretty accurate) then figured about how much thicker my new stuff would be (zero rate=1", 2 extra leaves at about .5" = 1" extra, so 2" extra to each side) and then just added a little more to be on the safe side...did that for the front and rear, filled out the order form, needed something like 3 that were 24" long and 5 that were 28", something along those lines, gave them my debit card number and a couple weeks later they arrived. There is a few other ways to do it but if you tell them the length of the rod to start with and what dia axle tube u need, they should be able to get it done for you right the first time. BTW, mine threaded about 4" on each side of the bolt.
  3. '71k204x4454
    '71k204x4454 Registered Member
    Dec 28, 2004
    60
    Hood River Or
