U bolts for zero rates
Discussion in 'The Garage' started by neverendingproject, May 15, 2006.
  1. neverendingproject
    neverendingproject 1/2 ton status
    Jul 24, 2005
    1,637
    Tulsa, OK
    Ive searched and for the life of me I cant find what I need. What size are the u bolts for a front 10 bolt axle with zero rates? I need the overal height and diameter of axle tube, on both housing u-bolt and axle tube u-bolt.
    thanks in advance
  2. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    Well for the D60 with a zero rate, there are two that are 5/8 X 3.25 X 9.5, and one that is 5/8 X 4 X 10, and two hex cap bolts that are 5/8 X 2.5. I know that that doesn't help you one bit, sorry. :crazy: At least the info for a D60 is out there now.
  3. neverendingproject
    Jul 24, 2005
    1,637
    Tulsa, OK
    Even If someone can find the link....
    that'd be great
  4. midnitewarya
    midnitewarya Sounds like a problem for future me. Premium Member
    Dec 1, 2002
    1,726
    20
    SoCal
    If I recall, you can use the rear 10 bolt ubolts on the front, and they have clearance. I have a new set that I never used because I blew the 10 before I put them on. Next time I'm over there I'll bring them and we'll see if they will bolt up.
  5. neverendingproject
    Jul 24, 2005
    1,637
    Tulsa, OK
    Well the two on the drivers side will work, but I need the big one and smaller one on the passenger side.
  6. midnitewarya
    Dec 1, 2002
    1,726
    20
    SoCal
    Naw, one side will be fine. :D
  7. neverendingproject
    Jul 24, 2005
    1,637
    Tulsa, OK
    Or I could weld the spring to the zero rate and weld it to the axle. :D
  8. midnitewarya
    Dec 1, 2002
    1,726
    20
    SoCal
    With the way that center pin sticks, I think you could get away with gluing it. :p:
  9. neverendingproject
    Jul 24, 2005
    1,637
    Tulsa, OK
    ttt still need answers.
  10. ntaj*ep
    ntaj*ep 1/2 ton status
    Feb 4, 2002
    3,248
    Evergreen state
    Its not a cut and dry question, as spring pack hieghts vary from one to another. Best bet would be to take measurements from your exisiting u-bolts or take the two passenger side u-bolts into a shop and have them order units an inch. or so longer.:D
  11. alf4444
    alf4444 1/2 ton status
    Nov 1, 2002
    2,051
    T-ville, ut.
    agreed measure your current ones and add an inch!;)
