U-bolts on 14 bolt FF
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BLzr4x4ngkid, Feb 5, 2001.
  1. BLzr4x4ngkid
    BLzr4x4ngkid 1/2 ton status
    Feb 18, 2000
    703
    Wichita, KS
    Are the u-bolts for a 14 bolt FF different from the 10 bolt? If I need new u-bolts for the bigger axle, do I have to get a new plate that sits on top of the springs? I'm new to all this 3/4 ton mumbo jumbo. This will definately be a learning experience for me.
    "Don't hit me with them negative waves so early in the morning." Odd Ball--Kelly's Hereos
  2. tRustyK5
    Jul 23, 2000
    36,163
    1,360
    E-town baby!
    Definitely get the upper plate if you can. The U-bolts for a 14 bolt will need to be bigger to accomodate the larger axle tube diameter (3 3/8" O.D.)
    Rene
  3. thatK30guy
    Jan 12, 2001
    32,076
    55
    I will try to find those plates for you. I know I have some somewhere, just have to find them. They are bigger than 1/2 ton and the rear u-bolts you will need will measure 3 3/8" x 11". I dont have these since I left them on the 86 when I lowered it.
  4. Stoopalini
    Stoopalini 1/2 ton status
    Oct 17, 2000
    999
    Austin, Texas
    You do not need to buy new plates. You will need new U bolts, but if you plan on using your existing 1/2 Ton springs, then stick with the 1/2 Ton Spring Plates too.
    When I did my conversion (10b to 14ff), I got new U-bolts from Steve over at ORD, and re-used the stock spring plates.
    All I had to do was squeeze the U-bolts together a little to get them into the 1/2 plate's holes.
    Thomas.
    -- '84 K5 Blazer --
    <A target="_blank" HREF=http://Stoopalini.coloradok5.com>http://Stoopalini.coloradok5.com</A>
  5. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color=blue>I had u-bolts made locally, then I just took a die grinder and enlarged the holes on the plates that came with my Rancho system.</font color=blue>
    <font color=blue>pavement queen with shinny paint job and car tires</font color=blue>
  6. Daveytree
    Daveytree Registered Member
    Nov 11, 2000
    57
    Kingman Arizona, U.S.A.
    When I did my 10 to 14 conversion I used the bigger plates. They fit just fine. Squeezing u-bolts together may work for now, but it doesn't seem like the best solution.
  7. thatK30guy
    Jan 12, 2001
    32,076
    55
    Yeah, thats true. When you squeeze u-bolts together like that, you are not giving the nuts a "square seating" for them to sit on the plates. The nuts will sit crooked, almost like an angle. You need to make sure your nuts sit flat on the plates.
  8. BLzr4x4ngkid
    Feb 18, 2000
    703
    Wichita, KS
    Hope you can find the plates. Glad I asked about the u-bolts. Would have felt really stupid getting home and the u-bolts wouldn't fit. LOL Thanks
  9. lowlevell
    lowlevell 1/2 ton status
    Jun 27, 2000
    343
    Central Ohio, USA
    The plates and u-bolts are different size.I recently did the 10 bolt to 14FF swap. The u-bolts are $13 each at the dealer. I bought a Skyjacker U-bolt kit.( actually, it was the U-bolt/bushing kit for a Skyjacker lift).I dont have any part #'s though, sorry.
    I will say, the biggest pain in the a$$ with this swap was finding the right springplate part# at the dealer.Their was like 5 different springplates that they said would fit my 14ff.And none of they're part #'s have measurements in they're computer.AND, most dealers(around me anyway) dont have these in stock.Later...
    P.S. I you havent bought the used 14ff yet, try and get the springplates when you do.The U-bolts are easy to find.
    One From None
