U-bolts??
Discussion in 'The Garage' started by chevy_mud_84, Jan 15, 2006.
  1. chevy_mud_84
    chevy_mud_84 Registered Member
    Feb 28, 2005
    89
    Brockville, ON, Canada
    im putting 3/4ton axles in my truck, and i know what size u-bolts i need for the rear 14ff, so would the front u-bolts be the same as the rear or no? cuz i plan on getting them tomorrow.
  2. colbystephens
    colbystephens 1 ton status GMOTM Winner
    Feb 24, 2005
    10,924
    20
    Oregon
    the fronts are not the same. odds are you can just use your stock bolts for the front end unless you're doing a lift b/c it's a 1/2 ton front end - but that depends on the year of the truck you're getting the gear from. check out this link - i asked the same question some time back, and the responses i got were accurate. http://coloradok5.com/forums/showthread.php?t=155145&page=2 hope it helps!
  3. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    1/2 ton ubolts are the same a 3/4ton u bolts fo rthe front. and actually they work on the left side of the d60 as well. the right side is alot bigger tho, and has the studs too
  4. trailblazr81
    trailblazr81 1/2 ton status
    May 27, 2005
    931
    Hollister, CA
    What year is the truck. Ive had experiences where older front axles and newer front axles had different size tubes and the u bolts wouldnt swap. Im talking like 73 vs. late 70's. Seen it on 1/2 and 3/4 ton.
  5. chevy_mud_84
    Feb 28, 2005
    89
    the 3/4 ton axles are out of an 85, and the 1/2tons in mine are 78.
  6. ProJunkRacing
    ProJunkRacing 1/2 ton status
    Jun 20, 2005
    1,229
    FrankFort IL
    buy mine got all of them plus 2 new spring plates
