U-Bolts
Discussion in 'OffRoad Design' started by FL84K5, Feb 26, 2003.
  1. FL84K5
    FL84K5 1/2 ton status
    Aug 19, 2001
    936
    Sarasota, FL
    Ordered some ORD zero rates and U-Bolts from ORD to be used with zero rates in the front with a 4 inch spring. I am going to go with a 6 inch spring in the front instead of the 4 + zero rate. Can I use the same U-bolts I ordered? Thanks
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I don't see why you couldn't. The ubolts you have should be long enough to handle a 6" spring if they will handle a 4" and a 1" zero rate. Measure them if you are not sure. Measure the thickness of the axle tube, spring perch, spring pack, and top plate. If you have 1" or more extra on the ubolt you will be fine.
  3. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    That's the answer for you.
    The TCI springs are not too much thicker in the 6" version compared to the 4".
