u-joint and shock mount parts?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by coolhandluke, Aug 26, 2003.
  1. coolhandluke
    coolhandluke 1/2 ton status
    Oct 23, 2001
    116
    Dallas Texas
    I need to replace the u-joint in the front drive shaft of an 8 lug 10 bolt, anybody know what the part # is or where to get one? none of the local stores say they have them.
    also, I just swapped a 14 bolt into the rear, but the shock mounts don't match up. where can I get some shock moutns to weld on?
  2. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    i can get you a good used pair of shock mounts 14 bolt FF 1974 pickup 3/4 ton
    want them ?
  3. coolhandluke
    Oct 23, 2001
    116
    Dallas Texas
    I think the problem is that they came from a pickup. Does a 3/4 ton truck have teh shock mounts on the same side as a blazer? does a 1 ton? that's what got me in the position in the first place.
  4. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    3/4 ton 4x4 truck has the same shock mounts as your K5. 1-ton mounts are flipped front and back. 2wd mounts hang a little lower.
  5. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    front ujoint from napa for an 84 K10=369....thats for the front shaft joint at the pumpkin..both joints for the rear shaft are 534g if you have inside clips..
