u joint caps turning in driveshaft
Discussion in 'The Garage' started by barneybasher1010, Mar 19, 2007.
  1. barneybasher1010
    barneybasher1010 1/2 ton status
    Sep 25, 2005
    908
    PORTERVILLE CA
    What can I do about the caps turning in the driveshaft? I can see where the caps spin in the driveshaft. I read something the other day but cant find it.
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Maybe the yoke is egged out a little bit , allowing the caps to turn . The clips are probably the only thing keeping them in there .
    It may cost you , but a new yoke , or at least a serviceable used one ( whole shaft ) would be needed .
    Use that one as a get home spare , if you tack weld the caps in place .
  3. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,995
    134
    ^^What he said^^
  4. rcamacho
    rcamacho 1/2 ton status
    Jul 1, 2004
    1,324
    WA
    Locktite between the caps and yoke may help a bit but will not fix the issue.
  5. YZEATER
    YZEATER 1/2 ton status
    Jan 21, 2005
    2,358
    TARENTUM, PA
    the u-joint could be locked up/worn out. it'll just keep wearing the yoke out.
  6. barneybasher1010
    Sep 25, 2005
    908
    PORTERVILLE CA
    I just installed the joints maybe 500 miles on them. They went on like any other u joint. It is a 1310-1350 conversion joint.
  7. 1977k5
    May 26, 2003
    9,995
    134
    The yoke in the driveshaft is worn out. You will have to replace it.
