u-joint carnage pics
Discussion in 'The Garage' started by 85mudblazin, Jul 31, 2004.
  1. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    At least your slipyoke and shaft survived. Mine was totally distroyed. Nothing was reusable. The only thing that survived was the #447 conversion joint, and then I lost the caps to it. /forums/images/graemlins/doah.gif Oops.
    Nice carnage though.
    Harley
  3. GMCLegacy
    GMCLegacy 1/2 ton status
    Jan 24, 2002
    620
    Grand Haven, MI
    come on, where is the story, there has to a story
    so there i was......
  4. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    ok so there I was one late night I was at a stop sign about to turn right and KKAAABBBOOOMMM crap went flying I get out look under the truck and there is no driveshaft I look around and there it is about 6ft away luckly I was only about 4 blocks from my house so I drove it home in 4wd leaving a tranny fluid trail, the slip yoke was went and I bent it back with a vise as best I could but I got some pretty bad vibes know so I am going to get a cv shaft built. Turns out the grease had left the caps in the u-joints and it just couldnt take it anymore and they failed. Thats what you get for crappy u-joints. /forums/images/graemlins/peace.gif
  5. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    talked to a drag racer that done the same thing with a brute force joint that was 3 weeks old, said the bearings in the two caps where a grey powder... He popped the shaft at the rear yoke 3/4 the ways down the strip... still finished at 109mph /forums/images/graemlins/yikes.gif
  6. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    That makes me feel alot better because I replaced them with brute force joints /forums/images/graemlins/doah.gif They were the strongest ones the auto parts store had, they could of got spicer but I needed to use my truck that day and they had to order them, maybe he just got a bad batch, all well. /forums/images/graemlins/thumb.gif
  7. Grim-Reaper
    7,385
    Atlanta
    Staps loadthe caps unevenly and cause them to be slightly oval. Makes them run hot and burn the grease out. U'bolts are better bucause the load the caps more even. /forums/images/graemlins/thinking.gif
