U-Joint change 101
Discussion in 'The Garage' started by grindkings, Jan 2, 2005.
  1. grindkings
    grindkings 1/2 ton status
    Dec 24, 2004
    127
    Marshall, Missouri
    As you can see I don't know how to change my U-Joints. I pretty new to the 4x4 field. Just can some tell me how to change my front U-Joints.? I beileve its my front that needs to be changed.
  2. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
  3. grindkings
    Dec 24, 2004
    127
    Marshall, Missouri
    okay thanks. Now how do i get my drive shaft off?
  4. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    which one?
    There are several u-joints in the front- Are you talking about the drive shaft u-joint by the axle?
  5. grindkings
    Dec 24, 2004
    127
    Marshall, Missouri
    Yea in the front on the drive shaft. I have bolts on my drive shaft that conects to the u-joints. Can i just take to bolts out? with the join't just fall out then withought beating on it?
  6. darkshadow
    darkshadow 1 ton status
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    if you undo the bolt the drive shaft will come off.
    you now have half the joint out follow the steps in the link above to remove the other side.
    it is the same proceduer for drive shaft joints as it is for axles
    good luck:thumb:
  7. DieselSub
    DieselSub Registered Member
    Dec 31, 2004
    22
    Northern California
    Here's a few things I'd do differently than the Pirate4x4 write up...
    1) You'll probably be at home, so use a bench vice to press in and out the bearing caps.
    2) If you're going to use a hammer to bang the bearing caps on or off, support the area around the cap opposite the one you're banging on with a socket, such that the bearing cap will fall into the big socket, and the sides of the socket will support the "ears" of the axle shaft.
    3) Clean up the inside of the "ears" on the axle shaft (where the bearing caps go into) with sandpaper so that there are no burs. Burs, nicks, roughness, rust, etc. will make installation that much more difficult.
    4) Make sure the clips that retain the bearing caps on "really in". Sometimes they look like they are in, but are almost there and will pop out when you need them most.
    5) If you can use 3/4 clips, instead of the 1/2 clips, they are much better.
    Also:
    1) Read the instructions that come with your u-joints. For example, my Spicers said not to add grease and to be very careful about keeping each cap matched to the bearing end it came off of. Of course, if you are using greasable u-joints, grease them after installation.
