U-Joint Combination # ?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 78Blazer, Jan 20, 2002.
  1. 78Blazer
    78Blazer 1/2 ton status
    873
    Michigan
    I have a 84 blazer with a 10 bolt rear and a driveshaft out of a 78 with a 12 bolt does anyone know what the combination ujoint number is for this? Also will I need one for the front shaft also or will it be the same ujoint for both years?
    Scott
    78blazer
  2. I don't know the number, but if you have both U-joints you can take them into NAPA and they will take the measurements and hook you right up with what you need. Good Luck !
    [​IMG]<font color=red>BigBurb[​IMG]
    <font color=purple>I Like my Burb'n on the ROCKS !!
    <font color=black>Imported to Kentucky through military channels !!
  3. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    Either Napa 447 (likely with your newer ride) or Napa 348.
    Your front should be the same as you're running now.
    <font color=blue>'79 ONE TON TPI K5 - See it at---&gt;<a target="_blank" href=http://www.blazzinor.rockcrawler.com/>BlazzinOR's Beast Buildup</a>
  4. FatBoyBlazer
    FatBoyBlazer 1/2 ton status
    Feb 22, 2001
    1,508
    Worcester, MA
    the 447 is the one for the 10 bolt to the 14FF
    hola
