U-joint constantly breaks....
Discussion in 'The Garage' started by jester, Nov 25, 2004.
  1. jester
    jester Registered Member
    Apr 30, 2004
    53
    Prineville, OR
    I constantly keep breaking the U-joint on the rear drive shaft at the t-case. I can only drive for about 1 to 2 days and then it breaks. I had 1/2 ton running gear with 3.08's and it was doing it, then I swapped out 3/4 ton running gear with 4.10's and it still does it. So I swapped out the drive shaft for anothing thinking that it may have been out of round or balance, but this one keeps doing it to. I have checked the t-case fluid and changed it. I only have a four inch lift and my blocks are slightly shimmed, so I don't think it's the angle. I have a NP203 transfer case. Any help would be greatly appreciated I would love to be able to drive this thing.
  2. blackblazer717
    blackblazer717 1/2 ton status
    Jul 1, 2004
    470
    massachusetts
    shim the t-case down with the factory round stock. than ditch those blocks for non saggy springs and a set of ORD shackle flips
  3. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    how are your angles? How extended is your drive shaft out of the tcasE?
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    If you're breaking u joints, they're binding, without question.
    I'd imagine axlewrap is causing the binding though...lose the blocks and it will probably stop binding.
  5. spoolnaround
    spoolnaround 1/2 ton status
    Apr 8, 2002
    1,419
    Kingsburg Ca
    This is what happens with extreme axle wrap.
    You dont have to worry about the u-joint just the yoke /forums/images/graemlins/doah.gif
