U joint for 82 driveshft to front 75 D44--brakelines ?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by ColAdo82K5, Jun 19, 2002.
  1. ColAdo82K5
    ColAdo82K5 1/2 ton status
    Feb 18, 2000
    789
    MO
    What is the u joint part number for a stock front 82 driveshaft to a 75 dana 44 ??? Also, i'm getting extended brake lines--so what year should i get them for ?? in steve fox's write up it says that the brake lines are different from a 10 bolt to a dana 44 ???
    thanks all,
    Blake
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    If you use the D44 calipers, use the D44 hoses.
    If you use the 10 bolt calipers, use the 10 bolt hoses.
    Either will bolt in each others place physically, but the hoses are different.
    As for the U joints, I sure hope they're the same. I want to use the front driveshaft from a '79 K10 (D44) on my '82 10 bolt axle.
